2025 Spanish Grand Prix - Barcelona-Catalunya May 30 - June 1
240
Re: 2025 Spanish Grand Prix - Barcelona-Catalunya May 30 - June 1
Lance Stroll is out due to a wrist injury.
I guess that means Drugovich in? Should be good.
Cs98
Cs98
Yuki was what, 5 tenths behind with an older spec car? I know many prefer conspiracies over recognizing greatness, but this was minor compared to some of the beatings Max has handed out to teammates over the years.
chrisc90
Don’t think they’ll be able to run a reserve driver as they won’t qualify for the 107% rule.
Expecting a 19 car grid
Vettel165
Q3 ANALYSIS
Many expected the 'flexy-wing' clampdown to hurt McL, but their quali performance was fantastic: excellent top speed, highest minimum speed in the slowest and fastest corners, sustainable deployment...
RBR: VER was full throttle for more time than any other driver. Only he didn't lift in T14! Downforce+bravery
Mercedes was well-rounded. The tow negated RUS's higher drag
Ferrari had no strengths, only areas in which it was less bad than others. 9km/h deficit to McL in T14, but also unimpressive top speed and high-speed cornering. The team has a lot of work to do.
240
chrisc90 wrote:
31 May 2025, 22:39
Could a pit lant start work?
The 107% rule is not applied all the time.
Farnborough
Farnborough
152
Vettel165 wrote:
31 May 2025, 22:40
Q3 ANALYSIS
https://postimg.cc/F71WRvmX
Against general Internet common projection of cold race = better MB performance ..... there looks to me a correlation of raised tyre pressure suiting MB chassis to a benefit greater than others find detrimental.
The pressure is raised by Pirelli to reduce flex in carcass, preventing too much heat to build from structural flexure, ultimately to avoid tyre failure during extended race stints.
This just seems to bring the MB chassis forward relatively in comparison to what the other front runners experience.
Seanspeed
Seanspeed
Vettel165 wrote:
31 May 2025, 22:40
Q3 ANALYSIS
Could have sworn I saw several drivers go flat through the final corner, including Russell, Leclerc and Piastri.
MB_Racer
MB_Racer
chrisc90 wrote:
31 May 2025, 22:39
Damn that is correct !
avantman
avantman
Cs98 wrote:
31 May 2025, 22:38
Old spec car? If only some very minor things, he got new, latest spec front wing this time and a floor as well as I understand.
As for his deficit, it was a whole second after the first run. He took the second brand new set and improved by 4 tenths as all others improved and Max would’ve improved as well if he needed to. Shortly after he took a nee set in Q2 and improved by 4,5 tenths. So, the real deficit of Tsunoda would be if not a full second then 8 tenths at very least, which is very in line with everything we saw previously.
Waz
Waz
Seanspeed wrote:
31 May 2025, 22:38
ringo wrote:
31 May 2025, 21:26
It does look like the car is designed for him. It's not the slowest car on the grid for sure. So something is definitely wrong at red bull. Either it's designed for him, or the 2nd drivers are barred from learning what the cars needs to be fast
Yep, as usual in life, something is only ever one extreme or the other. Can never be anything in between.
Seems to me the car is genuinely a bit difficult to drive, but when it's given optimal treatment by an extraordinary talent, can still be decently fast.
It's ridiculous to say this is the sort of car that Max is ordering his engineers to make. Max has complained about it more than anybody. And he was vocally against replacing Lawson for the SPECIFIC reasoning that he doesn't want Red Bull management to think the car isn't a problem.
I would be fuming if I was him at any suggestion the car is designed only for him. It's not even the quickest, it's difficult to set up and drive and needs a perfectly executed race from everyone just to reach the podium on specific tracks.
The finger should be firmly pointed at the technical team, not drivers. It's hard to fathom that nobody has been fired or reshuffled yet.
Waz
Waz
ringo wrote:
chrisc90 wrote:
31 May 2025, 22:39
I think after qualifying it's too late. The other driver needs to qualify themselves.
They can sub straight into Q without practice but not straight to a race.
avantman
avantman
Waz wrote:
01 Jun 2025, 07:59
Red bull technical group must be really really weak if the design the car specifically for Max but come up with understeery lazy behemoth at the start of each season since 2022 and it takes large part of a season to address it and balance it out somehow via upgrades and set-up compromises. Or probably someone should tell them Max doesn't like nor he needs understeer. Seems like they miss the trick.
Zhouvinazzi wrote:
31 May 2025, 20:51
Lazy wrote:
31 May 2025, 20:19
Max has a car totally designed for him, McLaren wouldn't do that. I think he'd struggle with the 39.
I don’t mean to be rude but this is just ridiculous bollocks. The car is designed by the engineers to be as fast as possible
and then it gets to Max, who has to drive it - not the other way around. He’s stated over and over that he doesn’t like the car,
and the only reason he’s on the front row with it is because he’s one of the best drivers in the history of the sport. To think he wouldn’t mop with the 39 is laughable but time will make this all clear
search
Same as last year (when Russell took the lead from 4th), there's a headwind forecast on the straight today. Should be another interesting start.
FittingMechanics
FittingMechanics
But the question remains, would Red Bull be better off constructors wise if they developed a car that other people can drive fast as well, maybe not outright top pace but still strong.
Their focus on Max and WDC could mean the team falls apart when he leaves. Put Tsunoda and Lawson in that car and where are they?
This is especially problematic for future development, they surely developed into some edge case of peak performance that can only Max extract.
