Driver styles/preferences
Re: Driver styles/preferences
So.... was Max trained like a child soldier or a child performer like the Jackson 5, or something in between?
Dee
Dee
PlatinumZealot wrote: ↑
18 Aug 2022, 03:22
Jos's own father was in the army, I can imagine him being a bit of a drill sergent at times with Max especially with training etc
New driver technique analysis Oliver Bearman:
[url]/url]
raymondu999
11 Jul 2024, 01:35
[url]/url]
A very nice URL PZ, thank you :lol:
ε€±θ΄₯θ€…ζ‰Ύη†η”±οΌŒζˆεŠŸθ€…ζ‰Ύζ–Ήζ³•
hsg
hsg
-1
raymondu999 wrote: ↑
19 Aug 2010, 19:45
Hey all. I think we know that many drivers prefer different characteristics of car handling. Is there some place where it's all consolidated together?
If not, I'll start. We know that:
These guys prefer a pointy, tail-happy car:
Hamilton
Schumi
Vettel(?)
Massa(?)
These guys want the tail to just stay put:
Webber(?)
Button
Lewis prefer oversteer?
r85
r85
hsg wrote: ↑
10 Dec 2025, 22:56
19 Aug 2010, 19:45
Hamilton
Schumi
Vettel(?)
Massa(?)
Webber(?)
Button
It has been a little weird since the GE era started. I think he can handle a loose rear but only if it's predictable, as he did with the W12. He does prefer a pointy car but needs the rear to keep up.
He cannot feel the ground effect balance shifts because they are so minimal in suspension movement but huge in change in centre of pressure. It's takes some learning that's for sure and his late braking style does not suit it.
Max Verstappen always had an early braking style that we can see from telemtry in previous regs and this is more easy to adapt for ground effect.
Perez and Daniel Ricciardo are other known late brakers.
Hmm.
New topic. Engine braking.
I'm not exactly sure how it disturbs a racecar driver, but I like it in street cars.
https://www.motorsportmagazine.com/arti ... is-is-why/
Furthermore, he hated the way Ferrari had developed engine braking as a way of aiding corner rotation. The whole set-up and aerodynamic philosophy of the car was based around that. β€œWhen I was at McLaren with Lewis,” recalled Heikki Kovalainen, β€œhe hated engine braking. In fact, he’d sometimes have negative engine braking.” Heavy engine braking combined with Hamilton’s aggressive entry approach just made for rear instability.
Gillian
Gillian
18 Jun 2026, 02:43
Hmm.
I'd say it's due to shifting during engine braking which can upset car balance. I'm suspect this is/has been Verstappens complaint when he says shifts are terrible.
671
there's no such thing as engine braking ....
it's PU braking
yes the shifts are worse than in eg 2025 ie the MG is more disruptive now ....
plus the gear ratios are wider ?
the PU rpm can accelerate itself at about half the ideal rate
though often this limitation is helpful to the driver
De Wet
Tommy Cookers wrote: ↑
18 Jun 2026, 18:02
it's PU braking
I'm pretty sure engine braking has been around as soon as manual gearboxes arrived... That's quite a few decades.
De Wet wrote: ↑
19 Jun 2026, 12:43
18 Jun 2026, 18:02
it's PU braking
I would guess he's referring to the fact that the ICE isn't the only thing connected to the rear wheels. The PU as whole - ICE and electric bits - drive and retard the car and the amount by which the electric bits do so changes depending on recharge strategy. The ICE part isn't even consistent as it's part of the overall strategy controlled by the ECU.
Hence, it's PU braking, not ICE braking as we would traditionally consider it.
It's just how it's called. Drivers still call the power unit the engine too, and that square thing that they call a steering wheel. :?
