Red Bull RB22
SiLo
145
Re: Red Bull RB22
Mouse hole entrance also a different shape?
Felipe Baby!
Re: Red Bull RB22
SiLo wrote:
27 Jun 2026, 08:29
For me no
Brahmal
Brahmal
83
Re: Red Bull RB22
Yep, just a weird shadow.
venkyhere
44
Re: Red Bull RB22
Usually Redbull are the ones to have large cooling exits, due to the air-to-air IC that they have traditionally had, since.... since forever. Comparing with SF26, the RB22 had much tighter engine cover and gills for a hot Austria track. Surprised.
Paa
Re: Red Bull RB22
venkyhere wrote:
29 Jun 2026, 17:02
https://ibb.co/qLYWcHfL
This could be related to the mysterious thing that the employee was referring to, that "would blow people's mind" (if they knew).
Possibly Red Bull came up with some major internal cooling update.
venkyhere
44
Re: Red Bull RB22
Paa wrote:
29 Jun 2026, 17:29
venkyhere wrote:
29 Jun 2026, 17:02
Isn't cooling architecture/components (excluding piping/routing/packaging) part of the 'PU system' that is locked unless released by ADUO ? What do the rules say ?
On another note, here is a good picture (Carpentiers) showing the side-by-side comparison of the sidepod inlet modification. Now it's looking very close to the Mercedes' inlet :
Can also see how the front wheel rim design is changed as well.
Re: Red Bull RB22
Paa wrote:
29 Jun 2026, 17:29
venkyhere wrote:
29 Jun 2026, 17:02
I don't think so. Red bull has had very tight cooling outlets for a few rounds now
tev33
tev33
Re: Red Bull RB22
Possible updates for Silverstone, not sure how accurate it is.
https://x.com/i/status/2071596309837119518
Re: Red Bull RB22
How big is this mouse :lol:
Re: Red Bull RB22
venkyhere
44
Re: Red Bull RB22
1. Didn't realize the 'mouse hole' was this big in longitudinal direction (maybe it's always been like this and not enlarged just now), since this is the first time the 'floor' has been pictured in this forum, as standalone ; and all the pics we have seen of it is from the front 3/4ths angle looking 'down' on the car.
2. Didn't realize how 'steep and sharp' the diffuser kick is, maybe the rake when attached to the car makes it a bit less aggressive, but still astounded by how they make the flow stay attached with such an aggressive kick-up, especially when there is no 'tunnel' like the previous era feeding it.
3. The mini-tunnel is still there inboard of the floor front fences
tev33
tev33
Re: Red Bull RB22
https://imgtree.co/i/bTok7JaB
Another view of the new sidepods from Austria
Mod edit: fixed the image for you. Check the post’s code to see how.
Re: Red Bull RB22
vorticism wrote:
24 Feb 2026, 16:17
Left to right: spec multi element wing -- "Winglet" -- diffuser & rabbit hole -- fence
The rabbit hole upper periphery extends quite far back, probably to the RS-Sidewall limit, and, as mentioned, looks to be taller than the belly of the outer diffuser ceiling.
Vorticism had previously noted that the mouse hole/rabbit hole extends rearwards. So this is not a new development, but does confirm it
Also we can see that red bull still have the mini vortex generators on the outboard face of each floor fence
Re: Red Bull RB22
