Aston Martin AMR26
SilviuAgo
189
Re: Aston Martin AMR26
avada
avada
Ozan wrote:
24 Jul 2026, 16:20
https://x.com/thomasmaheronf1/status/20 ... 0&ref_url=
i still can't understand how the least powerful engine requires the most cooling openings at the back of the car
They use the same amount of fuel (fuel flow limit), but produce more heat and less mechanical power than the others. Makes sense.
FNTC
FNTC
avada wrote:
24 Jul 2026, 17:15
Ozan wrote:
24 Jul 2026, 16:20
Yeah, less combustion efficiency, so less hp and more heat. Agreed.
deadhead
87
etusch
131
Ozan wrote:
24 Jul 2026, 16:20
If the ignition designs were good enough, less energy would be wasted, and if the design requires the engine to run hotter, they would do this by less cooling. Because once they achieve the fast combustion, the engine won't get that hot.
Beware of T-Rex
bigblue
Another fatal flaw of the AMR26, it's green so they can't see the flow viz. No wonder they have problems. Rookie error!
Brahmal
Brahmal
89
Ozan wrote:
24 Jul 2026, 16:20
Putting PU characteristics aside, you'll notice that the AM also has some of the smallest inlets. There are different ways to design a cooling system through the length of the vehicle: some go with small inlets and big outlets like AM, others go big inlets and small outlets like Alpine and Merc. It's just a design choice with trade-offs that each team will judge a little differently.
wiktor977
wiktor977
44
venkyhere wrote:
24 Jul 2026, 16:34
wiktor977 wrote:
24 Jul 2026, 15:27
sucof wrote:
24 Jul 2026, 14:53
This new more rigid solution with the horizontal connection might be telling about their past troubles.
Looks like they did great effort to have that strengthened part, so it might have caused the rear to misbehave.
To me it looked bad when they presented it, so I am not surprised.
This can also be the weight reducing solution, strengthening RW pylons for them to be able to take massive horizontal loads adds additional weight
The "horizontal connection" that you guys are referring to , has nothing to do with strengthening the RW pylons. It the rear leg upper wishbone "longbow style" (just like front leg upper wishbone at the front of the car) as mentioned by @AR3GP.
I didn't mean that. I said that maybe they introduced this connection to also reduce weight of the pylons.
Brahmal
Brahmal
89
wiktor977 wrote:
24 Jul 2026, 21:16
Very likely. They would have had to overbuild the previous design to keep it from flexing, whereas this is much more efficient from a structural standpoint. I'm also curious if they could give this crossbar an aero profile, though maybe the FIA would frown on that.
Brahmal
Brahmal
89
So what possible justification would there be for this massive scythe-like structure on top of the actuator pod? I'm wondering if this is more a canvas to stick a bunch of little winglets to later on than anything mechanical or structural.
FNTC
FNTC
Yeah, I don't understand the need for that bow on top there either. Very strange. It must have some kind of aero benefit, if not now, then in the future. If you look at the mechanics there, it would work the same without it. It only stiffens things a bit. Maybe the wing flexes too much without it so they had to add it?
Farnborough
Farnborough
152
Brahmal wrote:
24 Jul 2026, 21:40
https://cf.preview.redd.it/new-actuator ... b11424eb4a
It's static, as far as I can see. To support the centre hinge point at the furthest pivot from camera position. That pivot-point would be in alignment with the outer two holding the moveable flap. It arcs in such fashion to give clearance to front of flap rotating upward when deployed.
Presumably to give les wing cord/cross-section to that centre part of flap.
Possibly, without that, the flaps would bend backwards (belly out) under peak loading when closed.
FNTC wrote:
24 Jul 2026, 22:16
It's clearance for the new arm:
Beware of T-Rex
FNTC
FNTC
I'm just saying if you remove that top carbon fibre bow, the mechanics of the wing remains the same, look at it:
Unless its aero related I think the only reason is the top wing element fails its flex test or something without it.
