Renault R30
Mysticf1
Mysticf1
Re: Renault R30
The front wing, under the pressure of the air, collapses from February to March centimeters and provide better adhesion to the car.
:lol:
zgred
Re: Renault R30
Francesc wrote:Image
If You compare that two pictures You can observe that there are additional holes/slots close to endplates (low at the hight of the central slot), moreover from the front, main slot is closed in that width but from the back it exist in the full width.
Re: Renault R30
abd due to its feed you create an 3 plane wing, at least this is the closest you will come to such an wing.
mx_tifoso
mx_tifoso
Re: Renault R30
volarchico
volarchico
Re: Renault R30
Are those some fancy bottles of ride-height adjusting fluid or something else a lot more simpler than that?
mx_tifoso
mx_tifoso
Re: Renault R30
The latter; front and rear brake fluid canisters.
marcush.
marcush.
159
Re: Renault R30
full aluminium front bulkhead... when did we see that last time...
very nice touch with the bottles...you can see their support bracket is hinged on the right side so you can just swing them to the side for suspension access..
also the torsionbars left right are interconnected by that horizontal rod ,or better said ,usually are ...as the bolt on the left side is missing... hopefully
on purpose... :mrgreen: :mrgreen:
please forgive me for not referencing to the cars direction of movement but to our viewing position..not very engineerish...
Re: Renault R30
Renault win the prize for the most innovative passive rear wing of the year so far. That thing is impressive.
The main element is hollow, with the interior being fed from central and end top surface holes. The air from these is fed to a slot on the underside of the main element effectively turning it in to two elements. Clever use of connecting pieces ensure the whole thing complies with the rule requiring the use of just two unbroken sections.
What a great way to turn a 2 element wing in to a 3 element wing with all the efficiency benefits thereof. With the loss of the active f-duct systems next year, this type of rear wing will be the norm and I, for one, look forward to the variations that will appear.
I wonder if we'll see teams doing the same thing with the top element in order to create a 4-element cascade...
Miguel
Miguel
Re: Renault R30
mx_tifosi wrote:Renault sold out to Genii and since then they have promised to develop at a much faster rate than before. And new management and team structure compared to 2009.
Is there really any difference other than kicking Briatore out and not having Symonds available at all? I had the impression that losing Symonds would really affect them in a negative way. Regarding the development of the car this year, it may help that the R29 wasn't really developed from about June onwards. I think they got a new diffuser for Nürburgring and that's it.
In any case, yeah, R30's front wing is the oposite concept of last year's R29.
I am not amazed by F1 cars in Monaco. I want to see them driving in the A8 highway: Variable radius corners, negative banking, and extreme narrowings that Tilke has never dreamed off. Oh, yes, and "beautiful" weather tops it all.
"Prediction is very difficult, especially about the future." Niels Bohr
tok-tokkie
tok-tokkie
38
Re: Renault R30
mx_tifosi wrote:Image
I like the lightest possible mounting method used for those brake fluid bottles = zip ties.
I assume the front ride height is being adjusted in the picture. Early on there was speculation that RBR was able to do this in some secret way to enable special qualifying (& race) pace.
Notice the red & green port & starboard marking on the torsion bars.
mx_tifoso
mx_tifoso
Re: Renault R30
As good as an under shot can get while the car is on the ground.
xpensive
xpensive
214
Re: Renault R30
Can someone xplain the suspension-linkage between left and right in this picture?
i70q7m7ghw
i70q7m7ghw
49
Re: Renault R30
The steering arm?
marcush.
marcush.
159
Re: Renault R30
the levers are obviously connected to the torsionbars left and right (when all parts are in place so effectively the torsion bars work against each other when both wheels go in bump .In single bump this approach would enhance roll ...if there was not something restraining droop ,looking at the left side lever -bolt is missing there!) you can clearly see this corner did not move much ,and if the complete corner is mounted to the wishbone ,there is a drooplimit builtin somewhere,I guess.
the steering is low on the renault ,level with the lower wishbones...
xpensive
xpensive
214
Re: Renault R30
This is what I understand as well, just never seen anything like it, must be some anti-roll device in there, correct?
