SiLo wrote:Back on topic, why is he so good on the brakes? I feel this also helps him when peforming overtakes.
Yes he has a natural feel on brakes but alot of the stuff he does is text book stuff.
That´s why it rarley works on seasoned driver´s like Schumacher and Alonso etc.
Basically the trick when approaching someone from behind you completely disregard your braking spot where you normally would brake.
Instead you watch the guy infront and as soon as he hit´s the brakes, you hit the brakes.
It´s a really simple and effective move because you sort of claim the track as you do it.
You have to be careful though not to overshoot the corner as the guy on the outside might pull one on you by braking extra late, causing you to miss the apex, he can cut in on the inside and regain position.
Many of the things Hamilton does is not special, it´s more text-book stuff.
the funny thing is that he seems to mostly be the only one really executing all of his arsenal.
The truth will come out...
