Vodafone McLaren MP4-27 Mercedes
Crucial_Xtreme
Crucial_Xtreme
404
Re: McLaren MP4-27 Mercedes
beelsebob wrote:They can't be the exhausts, they break this rule:
The entire circumference of the exit should lie on a single plane normal to the tailpipe axis and be located at the rearmost extremity of the last 100mm of the tailpipe.
(part of 5.8.3)
Yes that is the exhaust, they point up and inward. But expect the exhaust to change.
sAx
sAx
Re: McLaren MP4-27 Mercedes (pre-launch speculation)
thestig84 wrote:
sAx wrote:
thestig84 wrote:Well it looks like my person got the intakes right again and nose being similar. Also see why he didnt have too much else to say...looks similar but very nice. Good job Mclaren
Don't quite see the aggressive design philosophy hinted at or areas that will raise questions around legality. Maybe that is to be played out during testing next week.
It looks nice, but....?
sAx
Everything I heard pointed at conservative evolution but people like to get carried away. If your referring to the removed autosport aggressive design/legality story I think that was a dudd quote and should be ignored.
Certainly would like to understand chassis design to maximise mass flow to claw back downforce and yet meet nose height restriction from new regs. Comparing Gascoyne's CT-01 which may not actually be a useful comparator, MP4-27 looks very conservative (at this stage).
sAx
Integrity, Trust, Respect.
Follow me: http://twitter.com/#!/sAx247
jamesalexw
jamesalexw
"Exhaust" panel is removeable so likely a dummy.
Engine cover is also a dummy as the hole at back is sealed.
If the exhaust is real it could possibly be using a venturi effect??
Joie de vivre
beelsebob
beelsebob
85
(part of 5.8.3)
Does "normal" mean perpendicular then? Because I don't see how they do unless it does - I take it to mean the exit must have one face only, no shaping.
It means that it's normal vector (a vector perpendicular to the plane) must be parallel to the direction of the tailpipe axis. It's the "lie on a single plane" part that it seems to violate though – unless it's an optical illusion, it seems to curve over the surface there.
Giblet
Giblet
Could this be a lateral rethink of the 'octopus' exhaust?
I thought the pipe had to be exposed.
raymondu999
失败者找理由,成功者找方法
Joie de vivre
ajdavison2
ajdavison2
30
Is it just me or do the sidepods look even fatter than the 26 towards the rear? :wtf: :wtf:
raymondu999
失败者找理由,成功者找方法
ledzep4pm
Much more rake that initially last year.
I hope they can tighten up the rear packaging before the first race. Im expecting a lot of that car to change.
I have a theory on the exhausts. McLaren think another team is doing something similar, but less extreme. They launch an extreme version, FIA quickly move to ban it using a technical directive. The other team looses there advantage ?
What do you reckon?
Twitter @ledzep4pm
Crucial_Xtreme
Crucial_Xtreme
404
I agree, I believe we've been sold a dummy on many things. Below is a HUGE picture of the MP4-27.
http://twitpic.com/8eb64c/full
Gridlock
30
Cup-holders for the rear wheel men during pitstops. Nothing else makes sense.
Definitely more rake, even in obvious "we made this out of balsa" form as seen here.
Pull-rod rear end.
Very square inlets, aren't they?
#58
Afterburner
DOn't know why but something tells me this isn't the final nose...
beelsebob
beelsebob
85
Gridlock wrote:And what's this?
I'm wondering if they're using the front wing f-duct idea to push air through to the splitter somehow.
