Red Bull RB8 Renault
Mr.S
Mr.S
Re: Red Bull RB8-Renault
agungn51 wrote:Image
Mr.S wrote:The car is f***ing amazing. Really is. I love the nose,the whole step down with the Driver Cooling,they have got something there. They are exploiting it.
The Front Wing is Amazing. God it's so complex & weird & hands down will not be repeated soon. The side-pods are not as sleek as Force India but the Under-cut is huge.
I still think it is a fantastic nose. I mean Step Down's are the norm & probably. 6 pout of 7 cars feature the same trick. I said it then & there -> Mclaren have lost the plot. Of all the step-down nose this is different,not that flat but with a slight curved shape.
I dont know if it's a winner or not but it should be a competitive car. Complete Evolution from RB5,6 & 7.
Of all the cars I like the Red Bull & Force India the best followed by Ferrai close by.
Care to explain?? I think Mclaren has the lowest nose & will have the least air flow under the nose.
Froggolo
Froggolo
is there some photo of the underside of the nose?
still didn't find anything
Relax, man. Have an elliptical drink or something® ( bhallg2k )
wunderkind
wunderkind
I don't think McLaren got the height on the nose cone wrong as some of you have claimed. I think Ferrari and Red Bull have exploited the step nose dimensions differently. The Ferrari has used the additional height of the front bulkhead for the pull rod suspensions where as Red Bull's air vent in the front bulkhead is there for aero gain, presumably.
I don't think the McLaren is at a disadvantage at all. The ground clearance underneath the McLaren's nose and the tub is similar to other 2012 cars we've seen so far.
I think what is most evident on the McLaren is how the front wing and the snow plough work together to direct air to the coke bottle waistline and to the back of the car.
Joie de vivre
NormalChris wrote:Think this is a different material than the diffuser of is it just an odd reflection? Defiantly doesn't seem to have the large checker weave. Caught my eye because they used a different material in the same location for the EBD last year.
Either way its a decent shot of the starter hole.
it looks like an outlet ... maybe the inlet is in the nose cone and air just flows inside the car to the rear and blows on diffuser?
Roland Ehnström
According to this article they are feeding the air from the inlet forward through the nose structure and down to the front wing: http://www.racecar-engineering.com/news ... he-f-duct/
Is this possible???
Ferraripilot
21
Roland Ehnström wrote:According to this article they are feeding the air from the inlet forward through the nose structure and down to the front wing: http://www.racecar-engineering.com/news ... he-f-duct/
Is this possible???
I don't see how so many turns would make stalling the front wing a possibility with such an inlet. It would have to turn 180 degrees and then 90 degrees at the wing pylons, and 90 degrees again to exit.
shelly
shelly
136
In the bottom right corner of the picture I see a slot similar to that of ferrari f150 behind the crash structure.
Maybe someone else has already spotted it and called it a chimney (which I do not think it is, but I may be wrong) Was it there already on the rb7?
If not, it seems interesting: semidetached crash tube on the rb7 while ferrari seems to have dropped this feature and it had last year
twitter: @armchair_aero
Ferraripilot
21
Could the hole in the nose be piped all the way to the rear of the car ? Say the diffuser? Legally?
raymondu999
Shelly - we've had that discussion a while back on the MP4-27 speculation thread. I realize it's not a chimney, probably, but I'm just calling it that for convenience's sake.
失败者找理由,成功者找方法
Okay my vision of the car; I havent seen it for 100% but this car gives me the suggestion that it's exhaust doesnt blow anything, just like pre-2010. This gives me the suggestion where their strength will be, where their closest contenders seem to be trying to blow things Red Bull goes the easy route, and probably the best route.
raymondu999
The path seems to run quite immediately into the beam wing so I'm not so sure it doesn't blow.
If it doesn't though; Mark Webber said in a Q&A that he wanted a drivable car. I wonder if that includes removing the inconsistencies of on/off-throttle downforce. Maybe the exhaust would ultimately provide better lap times; but an inconsistent car would probably be a lot harder to drive
失败者找理由,成功者找方法
marcush.
marcush.
159
a closed door is what it is:closed.trying to exploit this degree of freedom is a waste of time and recources.you can try to create funny noise with the exhaust now that´s about it really.
Red bull looks a bit lost in the woods judging from Mr.Neweys words he seems to have no real idea what to make of the current regs which just restrict him...maybe they have already switched their REAL effort towards the new regs ,working with Renault? this prospect makes things hard keeping focused on 2012s contender...and it shows.
shelly
shelly
136
raymondu999 wrote:Shelly - we've had that discussion a while back on the MP4-27 speculation thread. I realize it's not a chimney, probably, but I'm just calling it that for convenience's sake.
Yes I remember, I put the reference just to underline that was what I was referring to. The question is: was something similar already on rbr last year? I can not remember, I hope someone can
raymondu999
Nope, it's new
失败者找理由,成功者找方法
tjaeger
tjaeger
I am not an aero specialist, but I think the above outlines flow path lines are not quite right. The first point where, direction changes to air flow will take place is the very tip of the nose cone. Pressure and velocity will change there, together with re-direction the air. Once the air leaves the tip of the nose cone it likely will not even get directed onto the 'hump' but above the same. So, teh hump will likely not have any and if then a neglectible small influence. Likely some eddy style (dead water) circulation might go on. Probably below the nose cone and on teh side is what counts.
You cannot engineer out stupidity.
