Vodafone McLaren MP4-27 Mercedes
Dragonfly
Dragonfly
Re: Vodafone McLaren MP4-27 Mercedes
Image link corrected.
Spa 2012
Not seeing your image, dragon.
Wast it this? found it on autosport forums
This is opening a can of worms!! need more camera angles.
Dragonfly
Dragonfly
Thanks, n smikle
That's the image I wanted to link.
Placed the correct link for the other one.
Spa 2012
aral
aral
26
n smikle wrote:Not seeing your image, dragon.
What is of interest in that photo, is the 'telescopic' joint in the front wing pylons. Could there be some form of movement being catered for, here?
murtoidf1
murtoidf1
yup we've already seen the whole wing tilts backwards at speed slightly to reduce drag presumably.
Not sure about those two "openings" though, could well be a reflection due to the silver paint. Hopefully other angles will be posted which show what's actually going on
beelsebob
beelsebob
85
The openings are definitely not openings – the front wing pillars have to be a pair of closed sections symmetrical around the car centre line.
Lurk
To be exhaustive:
and between 125mm and 200mm above the reference plane
Anyway I also think it is just a reflection. I think about the elements mounted on the FW main plane.
Crucial_Xtreme
Crucial_Xtreme
404
Rear end detail
right click>view image
Owen.C93
Owen.C93
177
Little bit of an aerofoil shape on the ends of the turning vanes.
N12ck
Owen.C93 wrote:Little bit of an aerofoil shape on the ends of the turning vanes.
I see no snowplow :o
Budding F1 Engineer
Yeah they removed the snowplough and added the more 'fancier' dolphin fins...
I remember in 2010, Mclaren once removed its Mp4 25 snowplough in Barcelona
Dragonfly
Dragonfly
beelsebob wrote:The openings are definitely not openings – the front wing pillars have to be a pair of closed sections symmetrical around the car centre line.
Yep, I guess I am the next victim of McLaren's mirror paint :)
Spa 2012
Owen.C93
Owen.C93
177
Some slight modification to the front wing include the little curved parts on the end are ever so slightly more curved on the latest wing and the planes are slightly modified towards the inside. A whole new wing made just for some tiny geometry changes.
Right click-view to zoom in.
Old:
New:
aral
aral
26
Side view confirms that there is no opening on pylons.
Look like Sauber'S 2010 turning vanes
