Mercedes AMG F1 W03
dren
228
Re: Mercedes AMG F1 W03
veYda25 wrote:
Med4224 wrote:So gills are back?
we're screwed...
This whole area looks like it does not belong there... lets see if they just experiment with something in free practise, or if they use it in qualifying and race. i remember an interview with ross brawn after the first barcelona test where he said how happy they were with the car performing just as they expected without any cooling issues.
i'm sure it does not mean a bad thing at all.
Plus, look at the body pannel around the exhaust. It looks like they had planned different versions of this from the start.
Honda!
Rikhart
Rikhart
38
bonjon1979 wrote:
Rikhart wrote:
Crucial_Xtreme wrote:Merc duct opening??
[img]http://www.f1talks.pl/wp-content/upload ... 97.jpg[img]
image via F1Talks.pl
That is without a doubt the shadow of the top plane winglet, that is opened.
You're just plain wrong - look at the shape of the small plate on the end of the DRS flap that when closed will rotate down to cover that hole. It's clear as day that it's not a shadow.
What? Can you see that when it comes down, on the closed position, it will not cover the shadow at all? It´s not even the right shape, I have no idea how you can doubt it´s a shadow.
Reason: Removed image quoted from post above
Jack Malone
That is NO shadow, I´m sure...
Sam3219
I'm going to agree with rikhart here. It looks like a shadow to me.
siskue2005
siskue2005
70
Sam3219 wrote:I'm going to agree with rikhart here. It looks like a shadow to me.
me too
bhall
bhall
244
elf341
elf341
I find it hilarious so many people are adamant on whether it's the hole or the shadow, "I'm sure", "You're just plain wrong", etc.!
Really? 100% sure? Wow. I hope you are not engineers.
mix2mix
mix2mix
me too
Metalrulz
Metalrulz
-1
I remember some people on this thread talking about 2 pipes exiting the engine cover just above the gearbox.. so now the mystery is finally uncovered..but F-Duct or no F-Duct nothing can substitute pure aero performance..
Owen.C93
Owen.C93
191
Metalrulz wrote:I remember some people on this thread talking about 2 pipes exiting the engine cover just above the gearbox.. so now the mystery is finally uncovered..but F-Duct or no F-Duct nothing can substitute pure aero performance..
Those were unrelated.
Anyway can anyone spot any holes for air flow in here?
marcush.
marcush.
159
these gills look like:
what can be done if we get into temperature issues due to ambient temps?
lets open the exits a bit ...could well be they found a component critical condition when wading through the data or during inspection of the parts after testing.
at the start of the season you play it as safe as you can..finish is what counts.
Metalrulz
Metalrulz
-1
then those pipes could possibly be blowing the diffuser..it is a bit disappointing looking at those gills again.. they were having overheating problems last year but not expected the same this year... maybe they are not concentrating on the air flowing around the sidepods but more above them as they have the lowest ones of all the teams this year... just a possibility....
Owen.C93
Owen.C93
191
They were just exit pipes for the gearbox radiator. They wont have any effect on the diffuser unfortunately.
Schulteiss
Schulteiss
Those gills have nothing to do with overheating, IMHO.
This confirms that there is no ducting to the front wing. Any such ducting would need to be absolutely air tight! Not to mention quickly disconnecting for in race changes. I see no such fittings on the bulkhead so can we all confirm that there is no Ducting to the front wing from the rear wing? (doesn't rule out FW F-duct though).
