___ wrote:Interesting...shelly wrote:Reading scarbs' twitter reminded me of the existence of a minimum radius rule on rear wing cross section ( the one that caught out Sauber in Oz last year).Coefficient wrote:
Something like this:
Wouldn't this rule ban any shape like that?
FIA Technical Regulations Article 3.10.2:I think you could successfully argue that the concave radii in a void like that are not in contact with the external flow. If that was rejected, it would be impossible for the section to both be closed and to have concave radii that aren't exposed to the external flow, so the second part of the article would be redundant.With the exception of minimal parts solely associated with adjustment of the section in accordance with Article 3.18 :
- when viewed from the side of the car, no longitudinal vertical cross section may have more than two sections in this area, each of which must be closed.
- no part of these longitudinal cross sections in contact with the external air stream may have a local concave radius of curvature smaller than 100mm.
A square edge is just a curve with (close to) 0 radius.kenny5 wrote:Slot does not have to have curved edges, could be square / angled...
Read the thread more carefully. We are talking about the legality of slots in the RW.mix2mix wrote:how you do not understood what is the point? when DRS are open air come through the hole what are open, and this air go through RW and exit through this holes who are position on top RW, and reduce vortex which are creates when DRS are open. This is benefit,and this is all the wisdom about this.
is that the actual duct wing? it doesnt seem to have the chunky part like this?Owen.C93 wrote:A couple of higher res shots of the DRS system that may not have been posted.
Closed: http://www.formule1.nl/media/uploads/me ... 937.41.jpg
Open: http://www.formule1.nl/media/uploads/me ... 7151.2.jpg
Owen.C93 wrote:Read the thread more carefully. We are talking about the legality of slots in the RW.mix2mix wrote:how you do not understood what is the point? when DRS are open air come through the hole what are open, and this air go through RW and exit through this holes who are position on top RW, and reduce vortex which are creates when DRS are open. This is benefit,and this is all the wisdom about this.
Not to me.forty-two wrote:Sound too wacky to be true?
Pup wrote:The exposed ducts are most likely the switch, with the major flow happening elsewhere. Think of the old f-ducts - the wing covering and uncovering the opening is analogous to the driver covering and uncovering the old fluidic switch control with his hand.
But I'm wondering now if the DRS ducts aren't more like release valves. That is, if there is a wing being blown, there will be some back pressure in the system. The DRS holes could then be like release valves that lower that back pressure and so decrease the wing blowing beneath whatever threshold causes the wing to stall.Pup wrote:My guess is that the intake is the secondary inlet behind the main air intake, and the flow is going through the duct that connects to the beam wing. I think the beam wing is what's being blown, since it's outside the rules limiting the rear wing itself. Where the pilot flow from the wing goes, I'm not sure, but it could be hidden under or within the main duct. Someone mentioned two ducts were visible? I haven't been paying close enough attention myself. Anyway, I'm guessing that there's a fluidic switch, similar to before, under the engine cover that directs the main flow either through the duct to the beam wing or simply out the engine cover exit.
