I don't buy it. I just can't see an advantage to taking a small amount of air and routing it through a circuitous duct from one extreme end of the car to the other that can only be used in one place on the track and even then only under certain circumstances. It would be pretty serious alchemy if anyone could find some performance advantage in that.
I would think that the rear endplate DRS hole air exits out the rear somewhere to modify the airflow there, and that in itself is a pretty clever system.
If there are slots in the rear of the front wings, they may or may not be exhausting air from somewhere. I think it is conceivable that a slot in that location just may have some beneficial aero effect, kind of like a reverse Gurney flap (inset instead of extended). But if they are exhausting air from somewhere, that air is entering the wing from somewhere in the front of the car, not the rear.
