quixpeed wrote:here is a suggestion or conclusion from the debate between Renault part and Ross and the FIA part as well along with all the statements in that regard recemtly, it is argued over that as it is a secondary device or passive as Ross states, but a very interesting point here explains the function of the RW holes when DRS is open, my conclusion is :
that this RW hole is only a switch, why?? bcoz they said DDRS its passive and not directly activated by the driver, only by activating the DRS, after which i think it becomes a DDRS.
we've seen the tubes we assume that runs from the front bulkhead all the way around the engine compartment as we noticed they feed into the rear crash structure, they are possibly the air duct (secondary DDRS), but its activation is a valve switch that opens and closes by the opening the holes in RW DRS. it could be as simple as that...
that is an explanation for the passive and non driver assisted device on board the W03.
that means the holes do not channel air to the front wing neither they suck any in reverse. just a plain air pressure switch to activate a device or valve.
i hope its clear?? what is your opinion on this guys and thoughts if this could the principle of it?
I liked the idea in late March when I presented it to the forum for discussion. Thus far I've yet to see anything to contradict that idea.
quixpeed wrote:bcoz they said DDRS its passive and not directly activated by the driver
Passive in this case simply means that the system is not directly engaged by the driver; the driver engages DRS, which then activates the Daffy Duct. At least, that's my understanding of the matter.
As far as a truly passive system goes, I don't think it exists.
(These threads can't read themselves; we have to do it for them.
