Vodafone McLaren MP4-27 Mercedes
Nando
Nando
Re: Vodafone McLaren MP4-27 Mercedes
that´s from Canada right? I think it was introduced there but had no idea they kept it for Europe.
Crucial_Xtreme
Crucial_Xtreme
404
Nando wrote:that´s from Canada right? I think it was introduced there but had no idea they kept it for Europe.
The update was originally introduced in Canada. But this analysis is speaking of Valencia. So yes definitely used last weekend.
Nando
Nando
ok thanks, thought it was specifically made only for Canada due to the nature of the track,
Huntresa
Huntresa
Holm86
250
I mentioned in the start of the season that i believel McLaren would have a good advantage if it had had pullrod front suspension on the 27. Because of its allready low nose. Pullrod you further lower the CoG on the front.
Im pretty sure that all the difficulties Ferrari had in the start of the season was more related to the rear of the car. Both suspension and aerowise.
Im guessing that more than 2 teams will have front pullrod next year.
Lycoming
Lycoming
106
He's not seeking pullrod for the lower CoG. The advantages in that department are minute, as you have to strengthen the upper wishbone, which moves weight back up.
Like ferrari, if they do it, it would be for some kind of aero gain. As I understand it, the aero advantage ferrari gets from it is having it almost horizontal, which means it interacts with the front wing's wake in a more favourable way. Having the lower nose may not really make it any more suitable, as it could result in a larger angle on the pullrod.
On the flipside if you have a less extreme angle, the rod could theoretically be thinner, though the gains in that department are probably the most marginal.
Either way you look at it, the gains are not large, even by F1 standards. But its not a spectacularly difficult job to make it work, so I guess I won't be surprised if teams decide to move in this direction.
Huntresa
Huntresa
On the topic of low noses we still dont know if FIA is gonna push 2014 nose regs to 2013 to solve the step issue.
Holm86
250
Why would the upper wishbone have to be stronger in a pullrod configuration? I dont get that.
Red Schneider
Red Schneider
Lycoming wrote:Like ferrari, if they do it, it would be for some kind of aero gain. As I understand it, the aero advantage ferrari gets from it is having it almost horizontal, which means it interacts with the front wing's wake in a more favourable way.
Do they bulge the lower half of the pull-rod to give it a cross-section like an inverted airplane wing?
marcush.
marcush.
159
speaking of anti dive and antisquat geometries...why restrict yourself in the first place and controlling these by geometrical effects instead of controlling the suspension vertical response just with dampers and springs?
Why would you consider that a restriction?
simieski
simieski
No, they must be symmetrical as well as adhering to a pre-defined aspect ratio limitation. Ref tech regs 10.3
Thank you to God for making me an Atheist - Ricky Gervais.
Tim.Wright
330
marcush. wrote:speaking of anti dive and antisquat geometries...why restrict yourself in the first place and controlling these by geometrical effects instead of controlling the suspension vertical response just with dampers and springs?
To control the pitch (and roll) with springs/dampers only would require very stiff springs which is bad for the tyre in terms of road-holding (increased load variation).
Introducing anti dive and anti roll (roll centre location) diverts the pitch/rolling forces through the chasssis and suspension links and away from the springs meaning they will deflect less than the case with 0% anti dive and rch=0. This means you can use softer springs for the same amount of body movement.
Tim
Banki
Banki
Has anybody got an information what develops they will have in Silverstone?
myoozikk
myoozikk
Germany is the race to be looking out for.
