The update was originally introduced in Canada. But this analysis is speaking of Valencia. So yes definitely used last weekend.Nando wrote:that´s from Canada right? I think it was introduced there but had no idea they kept it for Europe.
ok thanks, thought it was specifically made only for Canada due to the nature of the track,Crucial_Xtreme wrote:The update was originally introduced in Canada. But this analysis is speaking of Valencia. So yes definitely used last weekend.Nando wrote:that´s from Canada right? I think it was introduced there but had no idea they kept it for Europe.
I mentioned in the start of the season that i believel McLaren would have a good advantage if it had had pullrod front suspension on the 27. Because of its allready low nose. Pullrod you further lower the CoG on the front.Huntresa wrote:http://totalf1.com/full_story/view/4214 ... _2013_car/
Do they bulge the lower half of the pull-rod to give it a cross-section like an inverted airplane wing?Lycoming wrote:Like ferrari, if they do it, it would be for some kind of aero gain. As I understand it, the aero advantage ferrari gets from it is having it almost horizontal, which means it interacts with the front wing's wake in a more favourable way.
No, they must be symmetrical as well as adhering to a pre-defined aspect ratio limitation. Ref tech regs 10.3Red Schneider wrote:Do they bulge the lower half of the pull-rod to give it a cross-section like an inverted airplane wing?Lycoming wrote:Like ferrari, if they do it, it would be for some kind of aero gain. As I understand it, the aero advantage ferrari gets from it is having it almost horizontal, which means it interacts with the front wing's wake in a more favourable way.
To control the pitch (and roll) with springs/dampers only would require very stiff springs which is bad for the tyre in terms of road-holding (increased load variation).marcush. wrote:speaking of anti dive and antisquat geometries...why restrict yourself in the first place and controlling these by geometrical effects instead of controlling the suspension vertical response just with dampers and springs?
