McLaren MP4-28 Mercedes
Forza
238
Re: McLaren MP4-28 Mercedes
F1 Australian GP - Friday FP - 15/3/2013
Owen.C93
Owen.C93
177
Another "downgrade" on the car. Reverting to a much earlier diffuser spec with the gurney taken off the edges.
http://www.formule1.nl/media/uploads/me ... 002.29.jpg
They also removed the gurney tab on the floor flickup.
bill shoe
bill shoe
151
Shakeman wrote:From Adam Cooper's blog,
Button:
So what is the problem with the "ride"? What exactly is he complaining about, is the suspension too stiff and noncompliant? I can't believe they've gone even stiffer?
Ride quality is obviously an umbrella term for a lot of factors but if anyone here can help understanding the McLaren ride issues I'd be most interested.
It looks like McLaren have more side-scrub on their front suspension than last year, possibly more than anyone else this year. Side scrub is lateral movement of wheel as it moves up and down. Up and down is intended, lateral is an unintended but inevitable consequence of the extreme drooping front a-arms. A-arms with lots of droop are necessitated by pullrod front suspenson, but Ferrari seems to have reduced the need for it compared to McLaren.
Don't know if this causes "bad ride" but it doesn't help. It can certainly hurt.
thestig84
Owen.C93 wrote:Another "downgrade" on the car. Reverting to a much earlier diffuser spec with the gurney taken off the edges.
This is a Williams?!
CjC
CjC
gray41 wrote:Maybe he cut a corner? :P
Illegal ride height
http://www.autosport.com/news/report.php/id/106081
The car must not have been running its 'plank' or it was but tge ride height was too low and would have worn the plank away in a race, any other thoughts?
Just a fan's point of view
Interesting that they removed the curves in the FW main plane and straighten it out. Usually that is a sign that they are gaining rear downforce. So the problems they are facing aren't aero-related, but bad driveability.
CjC
CjC
turbof1 wrote:Interesting that they removed the curves in the FW main plane and straighten it out. Usually that is a sign that they are gaining rear downforce. So the problems they are facing aren't aero-related, but bad driveability.
KingHamilton01
http://www.f1times.co.uk/news/display/07348 Maybe the mp4-28 won`t be around for much longer! think they will give it a couple more races before making a decision?
McLaren Mercedes
R_Redding
R_Redding
Gridlock wrote: anyone got a capture.
Does this help..
Rob
Matt Somerfield
Great shot from Sutton Images of the induced drag creating vapour trails at the Rear Wing tips of Jenson Button's car
myurr
myurr
Illegal ride height
The ride height was probably fine with the fuel level they had, but had they brimmed the tank it would have grounded the car. I doubt they would be deliberately targeting an illegal setup, more likely that was their baseline setup and as they ran it they realised they needed to raise the ride height a bit. That can also help explain why they looked fast early in the tests but then didn't do any interesting times thereafter.
Coefficient
Coefficient
Names ending in 8 seem to be bad for this team. Remember the MP4-18?
Australia 2013 - FP3 & Q1 (16.03.2013)
dave34m
dave34m
-1
Coefficient wrote:Names ending in 8 seem to be bad for this team. Remember the 18?
You could be right, it was a M8 that Bruce McLaren has his fatal accident
Huntresa
Huntresa
Also the MP4-8, the 1993 car, not the worlds best car... :P
