Toro Rosso STR9 Renault
Re: Toro Rosso STR9 Pre-launch Speculation
RicerDude wrote:https://pbs.twimg.com/media/BfAFt2gIIAASKw2.jpg:large
Cooling outlet on the floor?
I was also wondering about this. I think it's to speed up airflow beneath the small beam wing, creating a lower pressure there so that it better aids the diffuser.
Ferraripilot
21
The mini beam wing along the bottom is a probably very plain version of what's coming.
Pilatus
22
Aero porn, indeed.
oT v1
oT v1
underneath the driveshaft, on the left, there is like a silver hole down on the floor, even more cooling or something a bit more fancy?
The Power of Dreams
looks like they're blowing the rear crash structure too :idea:
Owen.C93
Owen.C93
171
stefan_ wrote:Check this out.
https://pbs.twimg.com/media/BfAHkltIYAAh_8b.jpg:large
via Gianluca Medeot
New dash to match the new SECU ?
outer_bongolia
Cooling outlet on the floor blowing the lower beam wing?
Looks like that.
This is of the more interesting back sides.
Skeptical scrutiny is the means, in both science and religion, by which deep thoughts can be winnowed from deep nonsense.
Carl Sagan
slimfitcasual
Obligatory:
Per ardua ad astra
Holm86
245
The integrated IR sensor is maintained.
The mirrors are integrated into vertical flow conditioners.
Very interesting front brake ducts.
Owen.C93
Owen.C93
171
Do I peek a turbine?
Rushman
Rushman
