![Image](http://i.imgur.com/R6GpuLq.jpg)
Bit odd.
actually, if you look close at the studio image, the front part looks removable, so there could be something into that. you can faintly see a outline/lightness difference. but indeed, it's different.SectorOne wrote:On the studio image it´s gone.
http://www.jamesmoy.com/getpreview.aspx ... jyeQ%3D%3D
Bit odd.
It's not an intake. It's carbon fibre.stfn_ger wrote:Another thought on the nosetip-intake: Is it maybe a ram-air design to pull as much air as possible into the chassis to create a zone of low pressure to "tunnel" the airflow between the pylons?
clearly an intake, couldn't be any clearer.Owen.C93 wrote:It's not an intake. It's carbon fibre.
Intake it is.Owen.C93 wrote:It's not an intake. It's carbon fibre.
No, just no. It's just a glossy piece of carbon fiber from the crash structure that has a vanity panel fitted around it.Manoah2u wrote:clearly an intake, couldn't be any clearer.Owen.C93 wrote:It's not an intake. It's carbon fibre.
http://i.imgur.com/HYPcnA9.jpg
Can you draw what you think it is? Or annotate? We are all clearly seeing an intake...Owen.C93 wrote:No, just no. It's just a glossy piece of carbon fiber from the crash structure that has a vanity panel fitted around it.Manoah2u wrote:clearly an intake, couldn't be any clearer.Owen.C93 wrote:It's not an intake. It's carbon fibre.
Well one other guy mentioned an S-Duct, I can see that below the nose near the bulkhead. But the guy I replied to talked about the "nose tip" intake.Diesel wrote:Can you draw what you think it is? Or annotate? We are all clearly seeing an intake...Owen.C93 wrote:No, just no. It's just a glossy piece of carbon fiber from the crash structure that has a vanity panel fitted around it.
They are not required to run with camera's in testing.Manoah2u wrote:where the heck are the camera's anyway?![]()
Yes, that is what we are talking about. It's suggested to work like this:-Owen.C93 wrote:Well one other guy mentioned an S-Duct, I can see that below the nose near the bulkhead. But the guy I replied to talked about the "nose tip" intake.Diesel wrote:Can you draw what you think it is? Or annotate? We are all clearly seeing an intake...Owen.C93 wrote: No, just no. It's just a glossy piece of carbon fiber from the crash structure that has a vanity panel fitted around it.
zioture wrote:It seems that there is a slot on the tip
The slot under the nose is divided into three parts
http://www.newsf1.it/wp-content/uploads ... l_rb10.jpg
