Red Bull RB10 Renault
slovik1024
slovik1024
Re: Re : Red Bull RB10 Renault
DarkJRO wrote:the rearwing seems to be connected to the rear-crashstructure. looks like a beam wing, only just narrower
Yes it seems to be lower than before and connected to crask structure
gandharva
252
Re: Red Bull RB10 Renault
A bit more brightness, so we can see more details.
Who said gurney flaps on the diffusers weren't allowed anymore? They have it all over the place.
H2H
H2H
Surprisingly good-looking or not-so-ugly-looking nose. In general the design philosophy doesn't to have changed all that much compared to last year with as much airflow going under the bulkhead and low around the sidepods to the diffusor. The coke bottle down low is narrow indeed with high, widened cooling outlets.
Back the pictures.
gandharva
252
Seems Newey wants all hot air he can get from engine and cooling near the diffusor.
motobaleno
definetely it's a really tight rear end.
I would see a rear-low image to better appreciate where the cooling air exits
motobaleno
gandharva wrote:Seems Newey wants all hot air he can get from engine and cooling near the diffusor.
are you able to appreciate where hot air exactly exits?
dren
228
That is the cover for the drive shaft that also functions as the lower suspension member. The rear wing is not attached to that. The rear wing is attached to the top of the diffuser.
The diffuser exits at the sides with no real defining edges. Very few strakes in the actual diffuser as well.
Honda!
gandharva
252
Right before the new "beamwing". Looks like it's all centralized with the outlet itself as low as possibe.
dren
228
That's not a beam wing, it's an aero neutral drive shaft cover/suspension member. They have had one for a few years now.
Honda!
JDC123
JDC123
30
Does the red bull have the tightest coke bottle area of the teams so far? Its hard to tell with images of each car from different angles.
gandharva
252
dren wrote:That's not a beam wing, it's an aero neutral drive shaft cover/suspension member.
Aero neutral. Of course! :lol:
DarkJRO
dren wrote:That's not a beam wing, it's an aero neutral drive shaft cover/suspension member. They have had one for a few years now.
yeah, my bad. seems my eyes are playing tricks on me.
but so i still can't believe the wohle rear wing is held by that little tiny support on the engine cover
Greetings
Dark JRO
dren
228
The rotating drive shaft it covers isn't, so it is of benefit...
Honda!
dren
228
It looks like the rear wing is attached to the floor and also by the small support.
Honda!
