Edit (photo @f1-Aero)
Why? It's just testing, everybody's on different programs and they're not racing. Lap times mean nothing, especially in this seasons pre-testing where the drivetrain is brand new.darkmninya wrote:Looking at magnussen time, im little worried, but i did expect that
I thought it was a reflection [SMILING FACE WITH OPEN MOUTH AND COLD SWEAT] sorrywesley123 wrote:No it's not, the drive shaft is visible
It took me a few times though to actually see the drive shaftTechF1 wrote:I thought it was a reflection [SMILING FACE WITH OPEN MOUTH AND COLD SWEAT] sorrywesley123 wrote:No it's not, the drive shaft is visible
If the wing is sending airflow outwards, then I think this nose solution won't last long as I can't see any other reason for opting for it. And it's not only me, Mark Smith was very cautious to say anything(obviously as he is a rival) but you can pretty much see how he thinks this Ferrari and Mercedes nose solution is not ideal.wesley123 wrote:The wing is outwash, just like previous years and every other car on the grid. The pillars are inwards and will allow some air to pull in under the nose.
Also, the diffuser isn't necessarily missing any area, since it is the center section which will get closer to the ground than the rest of the floor, thus, it is more prone to stalling. Having a less critical shaped area prevents this from happening.
Ferrari's monkey seat seems to be way higher than the others, but I'm not sure of the reason for it.Hail22 wrote:On the monkey seat, from where I can see on the photos, is it passing the rear crash structure? or are my eyes slightly aloft?
If it is, my view is the exhaust could blow hot gases onto the monkey seat pushing air upwards in order to break up the drag created by upper flap / element of the rear wing whilst the DRS flap is closed, unless I'm mistaken? (which I feel I might be).
