Mercedes AMG F1 W05
beelsebob
beelsebob
85
Re: Mercedes AMG F1 W05
Giando wrote:
mix2mix wrote:Now Hamilton go out with different engine cover:
http://images.scribblelive.com/2014/3/2 ... 14_800.jpg
Sorry but i believe that's photoshopped.
The fin dimensions do not respect the mandatory sizes in height and lenght, imho.
Anyone?
Multiple analysis tools disagree with you. 3 different techniques all say this is a genuine image. Here's the output of the most reliable one. As you can see, nothing unusual at all going on around the fin.
NathanOlder
Very cool. What tool have you used there Beelsebob ?
GoLandoGo
Lewis v2.0
King George has arrived.
beelsebob
beelsebob
85
NathanOlder wrote:Very cool. What tool have you used there Beelsebob ?
That particular image comes from this tool http://fotoforensics.com/tutorial-ela.php
Emerson.F
Emerson.F
SuperSofts are one gloves are off...
Supporting: Ham/Alo/Kimi/Ros/Seb/Hulk/Ric/Mag
mikeerfol
68
From Sky Sports F1
zoro_f1
-2
tweet's are not visible at my computer... i must quote the message, copy the link and open in new tab/window.
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
Emerson.F
Emerson.F
Final run.. show us some magic Hami.
Per
Per
35
Javert wrote:
LightningLewis wrote:Isn't it a bit worring how much more cooling the Mercedes need compared to e.g. the Sauber, the RB and Ferrari? The others just seem to be so much more compact packed at the rear while Mercedes need the HUGE opening at the rear.
Are you kidding us? :mrgreen:
Better having mileage and big openings than small openings and no mileage!
Ferrari has slightly less powerful engine so they need less cooling
That's a remarkable way of thinking. If they have a less powerful engine, they need MORE cooling, since they are using the same amount of fuel (I think this is safe to assume given the rules). Less fuel converted to kinetic energy means more fuel converted to waste heat...
beelsebob
beelsebob
85
As was covered on another thread, not necessarily. Less power can simply mean less of the fuel being burned less efficiently.
timbo
timbo
113
beelsebob wrote:Less power can simply mean less of the fuel being burned less efficiently.
Are you saying someone is not gonna burn all the fuel provided? :)
And if it's burn less efficiently, it means more is converted to heat than work.
Per
Per
35
beelsebob wrote:
Per wrote:
Javert wrote:Are you kidding us? :mrgreen:
It was actually this very thread, I should have read to the end before reacting, sorry.
But you are implying that Ferrari is throwing more fuel out of the exhaust than Mercedes. Is there any reason why they would want to do that?
Maybe we should move this discussion to the 2014 engines topic? I find it interesting but it's off-topic.
beelsebob
beelsebob
85
Yes, I'm saying that ICEs don't perfectly burn all fuel. This is a major source of inefficiency in engines.
Or partially burned by-products that could be burned more. And no, in the current ruleset there's no reason I can see that you would want to do that – but that doesn't mean you can perfectly avoid it.
Chuckjr
37
If so maybe they still are having some brake by wire issues? Was he locking up on the SS laps?
Watching F1 since 1986.
diego.liv
diego.liv
Is floor width mandatory for all cars?
I'm not so sure about Ferrari's aero advantage in middle-rear of the car..nobody has that much floor visible in the sidepod zone as Merc, the point of max width of the bodywork
Thanks to f1fanatic
Ferr
http://www.f1fanatic.co.uk/wp-content/u ... 2014-3.jpg
Merc
http://www.f1fanatic.co.uk/wp-content/u ... 014-32.jpg
Ferr
Merc
http://www.f1fanatic.co.uk/wp-content/u ... 014-21.jpg
I couldn't make a good comparison between sidepod's areas and sidepod's height
Owen.C93
Owen.C93
177
Floor width will be the same. The merc just has smaller sidepods.
