Red Bull RB10 Renault
jagunx51
185
Re: Red Bull RB10 Renault
turbof1 wrote:That picture was damn confusing; it looked like the pillar was actually resting on the exhaust, but optical illusion messed up the view between the pillar and the RW endplate on the background.
they are very different in detail.... sorry cannot give clearer pics ...... look at the bahrain version, it is bended on the front side
atanatizante
133
1. Blue arrows : possible the corresponding slots for the holes in the inner RWEP?
2. Yellow circle : very curious bulbous structure ... maybe they have a passive DRS and the green arrow shows us the holes that are feeding the supposed channel inside it?
3. Magenta circle and pink arrow : did they have had it before?
4. Pink arrow : they are allowed to have a Gurney onto this carbon fiber covers? it`s not applying the same rule like suspensions have?
Jesus
1. Possibly. Or a reflection of something next to the car.
2. No passive DRS. Bulbous because of the piping that powers the proper DRS flap + green holes look like fixings.
3. Not sure
4. Looks more like the whole item is locally thickened. Look where it abuts the crash structure and you can see the upper surface is flat and just runs to the thick training edge.
SectorOne
https://twitter.com/ScarbsF1/status/444780765675388928 Also surprising to see RB once again going the other direction as seen with the monkey seat below the exhaust rather then above it.
What is the main difference of the locations?
hollus
Monkey seat helping the diffuser rather than the wing. Cameras hidden so as not to disturb vortexes. Stuff to reduce the drag (read downforce!) of the rear wing...
How much downforce if the floor of this monster producing?!
¡Puxa Sporting!
trinidefender
trinidefender
318
hollus wrote:Monkey seat helping the diffuser rather than the wing. Cameras hidden so as not to disturb vortexes. Stuff to reduce the drag (read downforce!) of the rear wing...
This may actually be incorrect, downforce may not be reduced by the floor slots. In aircraft the vertical wingtips (called winglets by boeing and wingtip fences/sharklets by Airbus) they actually reduce drag and help lift production. This is because the tip vortex effectively reduces the span of the wing that the vortex rotates around. By having the vertical wingtip you reduce the size and strength of the vortex effectively getting back most of the span of the wing you lost without the wingtip.
Force India has kinda of a double monkey seat, one in the RB10 position another where everyone else puts it.
I wonder if it will catch on.
ALOT!!
The redbull was on crazy rails in the wet!
In Q when everbody's engine power was equalized by rain this car is head and shoulders above the rest.
beelsebob
beelsebob
85
ALOT!!
Right, which is how Hamilton was able to set a faster lap, despite going sideways for 50-100m. Alternatively, it could just be that the RB10 is a good car, but not quite there yet.
I expect it'll be on a par with the Merc once they've got as much running in as Mercedes have.
ALOT!!
Exactly my point. the RB10 was on rails. Hamilton only got lucky that he could punch in more power with the full wets.
shelly
shelly
136
I think that the new slots in the rear are not for reducing drag, but to aid downforce of the rw.
They are placed below the wing profile - pressure is highr outside the endplates than inside in that zone
Rbr have had to fit the rw into the new legality box, so if the wing is aggressive the rear of it is steep, it needs slot bleeding from outside of rw not to stall. same as on the ouside of front wing endplate on most cars (for example f14t)
twitter: @armchair_aero
gandharva
252
The more other stripped cars I see, the more I wonder why Newey has packged that much cooling space. The radiator area is so much bigger than any other cars (even Renault powered Teams) are running. Do they really need that much cooling? Or is it to bump engine efficency and/or power? :?:
timbo
timbo
113
gandharva wrote:The more other stripped cars I see, the more I wonder why Newey has packged that much cooling space. The radiator area is so much bigger than any other cars (even Renault powered Teams) are running. Do they really need that much cooling? Or is it to bump engine efficency and/or power? :?:
http://i.imgur.com/zRX9LBY.jpg
One thing is the angle and probably width. I guess the idea was to get sidepods to be less bulkier, so they had to be narrow, which forced them to be longer and more angled.
Maynard G. Krebs
Maynard G. Krebs
That rear radiator doesn't look as nicely machined as one might expect. I wonder if that is something they've had to modify very recently.
Sandropim
Sandropim
Red Bulll have added 5 'u' holes to the bottom the diffuser, much like Mercedes' starter hole idea. (via @LuisFeF1)
Venturi Tube?
