Red Bull RB10 Renault
blokkie
blokkie
Re: Red Bull RB10 Renault
jagunx51 wrote:
blokkie wrote:
jagunx51 wrote:what is the 'belt-thing' for ?
http://i.imgur.com/E1WQzdz.jpg
http://i.imgur.com/LRmcSgh.jpg
To seal off the wholes while heating up the breaks
http://img4.auto-motor-und-sport.de/Red ... 767120.jpg
heating the brakes with what ? i don't see the heat-gun as on E22
http://i.imgur.com/rCGvO7r.jpg
Diff car .. diff brakes ..
check the transparent hose in the background ..
Which leads to ...
basti313
basti313
32
gandharva wrote:Look at the details (yellow circles). The green part is even more interesting. I think it allows the upper 3 elements on the outer side of the wing to flex downwards on high speeds and it comes up again on low speed. Per default the outer part is set up a bit higher (adjustable by the 2 screws i suppose) to support low speed front downforce. Nice stuff!
http://abload.de/img/unbenannt-15jlqm.jpg
I think you are on the right trace:
The aluminum flat bar does not look flexible at all. If I wanted something not to flex this is what I would use. On its step there may be a joint as the lower part is wider. So this thing is just a support.
On the other hand there is no visible connection at the slot with the yellow circles. So I think the upper, green connected part flexes in two steps and the round "hooks" on the side control the flex.
This would also include the front wing adjustment: The screw just controls the prestressing of the two, round "hooks".
Don`t russel the hamster!
lio007
327
any pics of RB's (Vettels) flow-viz-run in FP2? A lot of the rear end was painted with it...
boyracer94
boyracer94
Via @tgruener on twitter:
FrukostScones
boyracer94 wrote:Via @tgruener on twitter:
https://pbs.twimg.com/media/Bj0OgV_CEAE0Emf.jpg:large
Truck me harder! :shock:
Formula1.com
Darknight
Darknight
I have never seen the Redbull run big rake without performing really well. Renault engine or not I would say the redbull will be super fast tomorrow.
e30ernest
e30ernest
27
The rake may be exaggerated by the angle of that photo. Also, the car appears to be braking.
Gridlock
42
It's almost lifting the rear left wheel, looks like, plus the deformation in the FR, so not really a useful rake shot.
Edit - well, I guess it is in a way, because there's no arguing that under cornering conditions that would be an 'available' rake.
#58
timbo
timbo
113
e30ernest wrote:The rake may be exaggerated by the angle of that photo. Also, the car appears to be braking.
The rake is exaggerated by the undulation of the track. In that place it drops rather steeply.
lio007
327
found a little better one, though pretty low res
lio007
327
they also ran a revised/bigger opening for the nose-camera:
Darknight
Darknight
See what I mean... When redbull run rake, they run upfront.
just-right
just-right
Best Chassis on the grid. As soon as the engine / ERS is fully up to specification this car is going to be very quick indeed.
Godius
186
Interesting angle:
