No, it was on the F14T as well.Morteza wrote:Is this new?
looks like the 2015 PU has a lot of mass packaged lower in the car... can only be betterf300v10 wrote:Here is a comparison from @techF1LES. The intercooler appears to be in the same location inside the V.
https://pbs.twimg.com/media/B-ON5l5IgAADSAx.jpg:large
Open the image in a new tab for a larger view.
Is that the box Scrabs was talking about?f300v10 wrote:Its a shot of the Sauber, but the first view of the 2015 Ferrari PU. Exhaust is not 'log style', but does not wrap over the cylinder head like last year.
https://pbs.twimg.com/media/B-OJnpgIIAAVbqy.jpg
Mercedes changed their nose twice during the season last year, and Toro Rosso introduced a new nose in Japan. It could be that the teams will go through the tests with these noses and introduced a shorter nose during the season once they pass the crash test. We've heard rumours that Ferrari and Toro Rosso are both actually planning to do soAlainProst wrote:Do you think Ferrari, mcLaren and Toro Rosso will change their noses ? It's the 2nd session of practices and they don't have change them so I think it's the final noses. What do you think ?
I think it could be. I've been trying to find an image of the Ferrari PU without the engine cover. He did mention it was above the gearbox, which made me think it would be under the exhaust but I guess this is technically still above the gearbox.fawe4 wrote:Is that the box Scrabs was talking about?f300v10 wrote:Its a shot of the Sauber, but the first view of the 2015 Ferrari PU. Exhaust is not 'log style', but does not wrap over the cylinder head like last year.
But at point where rules allow that. There is set minimum CofG height.giantfan10 wrote:looks like the 2015 PU has a lot of mass packaged lower in the car... can only be betterf300v10 wrote:Here is a comparison from @techF1LES. The intercooler appears to be in the same location inside the V.
FIA tech rules 8.1.2015 wrote:Weight and centre of gravity :
5.4.1 The overall weight of the power unit must be a minimum of 145kg.
5.4.2 The centre of gravity of the power unit may not lie less than 200mm above the reference plane
Setup response finally OK then. That's good news, one problem solved.James Allison: “Overall we are content with the day, happy because the work we’ve been doing in learning how the car responds to set-up changes was very satisfactory, less happy with the laps count for the day. I hope that in the remaining days we get some more mileage under our belt”
