Mercedes AMG F1 W07
Spacepace
Spacepace
Re: Mercedes AMG F1 W07
Could that nose we thought was shaped funny on the filming day at silverstone be the updated nose?!
pmneo
pmneo
Formel1.de wrote that merc will bring a unusual new Front Wing today: http://www.formel1.de/news/testberichte ... m-dienstag
And AMuS wrote that they will bring a new nose on wednesday: http://www.auto-motor-und-sport.de/form ... 62629.html
atlantis
atlantis
21
LookBackTime
LookBackTime
472
Mr.G
34
Suggestion for name - hair trimmer
LookBackTime
LookBackTime
472
FrukostScones
that combine harvester is outlandish.... Game Over! :(
F1T
Administrative bot
Mercedes' W-floor, end of the bargeboard?
Mercedes' W-floor, end of the bargeboard? - Development blog
Having completed more than the targeted mileage on the first day of testing, and actually topping their mileage record from any test session since the introduction of the current engine regulations, Mercedes are again one step ahead of the competition as they have already started to add new aerodynamic components on their car, a single day after the W07 debut.
Named the W-floor by Mercedes, the area ahead of the sidepod now features a number of serrated horizontal and vertical panes, all aimed at directing or contioning airflow towards the rear of the car. The more conventional layout here is to have a barge board, which is a solid vertically standing panel that guides air away from the centreline of the car, and around the sidepods. The thing is that with sidepod undercuts becoming so thorough and smooth, that there is less need for such a panel, forcing teams into the investigation of other things to put in this - largely unregulated - area.
So, instead of pushing air outboard, the 6 new panels allow for air to bleed through the system, into the low pressure area that is behind the "combined bargeboard". The interesting bit here is that each vertical panel attached to a seperate forward extension of the floor. And just like with the vertical items, this used to be a single, continuous panel of carbon fibre.
However, as air is flowing outboard in this area, the slight curve in the floor extensions help "fetch" some of that air, and push it underneath the floor, where it will be worked further downstream by the diffuser to create efficient downforce all over the car's floor.
Judging the complexity of the elements, it looks unlikely that many teams will be able to copy this rapidly, but one can wonder if this is the beginning of the end for the traditional barge boards that have existing on F1 cars for numerous years.
That would have gone well back when Renault had the front blown exhausts :lol:
Mercedes going back to their Brawn (Braun) roots...! :lol:
e30ernest
e30ernest
27
That seems a bit scary though... imagine what could happen if a driver misses his stop in the pits slightly.
variante
139
The thing about this "W-floor" (or "air trimmer"...) is that it seems to sacrifice -at least partially- the vortex shed by the lower edge of the bargeboard. To my knowledge, the positive effects of this vortex are kinda huge, so the new system must be very effective. Also, it doesn't seem like the new elements are trying to produce smaller vortices on a wider scale... Probably they work taking advantage of the excess of high pressure (just in front of the sidepod) to increase the airflow that will be extracted by that little diffuser on the side of the floor.
Sounds like a good theory?
SparkyAMG
e30ernest wrote:That seems a bit scary though... imagine what could happen if a driver misses his stop in the pits slightly.
Anyone in front of the car would have had their legs chopped off by the front wing and then run over by the tyre by the time these teeth got anywhere near!
I love the look of the W floor, it's a really aggressive piece of bodywork suited to such a car. First bit of significant innovation we've seen on an F1 car in quite some time... Hopefully it's effective.
Let's not excagerate: in the pitlane the speed is that limited and the technicians wear protective gear. no shopping off of bodyparts included.
And for the record: this is not a novelty. Renault did run similar bargeboards in the past, a few years ago:
https://formula1techandart.wordpress.co ... 1-renault/
