Mercedes AMG F1 W07
pmneo
pmneo
Re: Mercedes AMG F1 W07
Via Amus:
The intercooler was moved directly above the turbo
The Shape of air box was slightly changed in the lower region. The sensors inside are gone.
Sonic
Sonic
Sonic
Sonic
diego.liv
diego.liv
The completely upgraded car
Rear http://img1.auto-motor-und-sport.de/Mer ... 935566.jpg
Cooling openings http://img1.auto-motor-und-sport.de/Mer ... 935591.jpg
6 slots yet, maybe slightly modified? http://img2.auto-motor-und-sport.de/Mer ... 935587.jpg
OT: talking about microaerodynamics Image
pmneo wrote:Via Amus:
http://img3.auto-motor-und-sport.de/Mer ... 935581.jpg
Not sure that is the intercooler. More likely an oil cooler or battery coolant.
Putting the intercooler there would result in a long trip for the air from the compressor at the front of the engine to the cooler and then back to the plenum. Exactly the opposite of their philosophy. It would also increase heat soak in to the cooler from the turbo.
FrukostScones
dans79
267
It looks like almost everything they tested is on the car., including all the "draggy" bits people have worried about. it will be interesting to see how much performance Merc held back during testing.
206 177 106 104 9 9 7
Juzh
161
dans79 wrote:It looks like almost everything the tested is on the car., including all the "draggy" bits people have worried about. it will be interesting to see how much performance Merc held back during testing.
My guess, a lot.
bill shoe
bill shoe
151
dans79 wrote:It looks like almost everything they tested is on the car., including all the "draggy" bits people have worried about. it will be interesting to see how much performance Merc held back during testing.
Toward the end of testing they trialed a new front wing with (presumably) improved aero but an inability to meet the FIA static push tests for rigidity. It had very pinched (vertically thin) transitions between the central "spec" section and the outboard "free" sections, so just not enough vertical section modulus at the transitions. Merc claimed it was not yet rigid enough to pass.
Is that wing on the car now? What material has the highest stiffness relative to volume? Boron fibers or something like that?
mantikos
mantikos
35
...umm, either you just made that up or you are getting this confused with the fact that no one had passed the wing test because the FIA had not administered it.
Btw, hello fellow Dallasite :)
dans79
267
it looks like they are also running the split flow conditioners, has anyone heard what exactly the split is supposed to accomplish? yet another vortex?
flickerf1
flickerf1
dans79 wrote:it looks like they are also running the split flow conditioners, has anyone heard what exactly the split is supposed to accomplish? yet another vortex?
I posted a link to a Motorsport.com article that gave a brief insight into what the updates that were placed on the W07 did during winter testing on the previous page. :)
The Wicked + The Divine.
mkable1370
mkable1370
Can anyone tell is that serration only on the trailing edge of the lower element on the rear wing? My mind almost sees variations in the light/shadow on the bottom side of the wing suggesting the serrations are carried forward on the bottom of the wing. Am I imagining that?
OO7
OO7
171
That front wing is the same as the one fitted to the car in the following images:
There was an article stating that it had failed load tests, however it was reported elsewhere that Paddy Lowe had refuted such claims and informed that the new wing had passed all the Mercedes internal (F.I.A standard) load tests.
dans79
267
I saw that, but it's not very descriptive, it basically described what every conditioner is supposed to do.
These changes work in unison with both the revised bargeboard and vane that hangs from the sidepod shoulder (below), improving how the airflow moves around the sidepod.
