Mercedes AMG F1 W07
Jolle
Jolle
133
Re: Mercedes AMG F1 W07
Blaze1 wrote:Kimi's start on the other hand was just as bad as Lewis'. I'd say it was about on par with Rosberg's if exclude Kimi's slow reaction time.
That could also just be Kimi :P
If he was a footballer, he wouldn't practice penalties either. Vettel on the other hand, being German... The natural love of procedures and practice. :D
domh245
domh245
30
What is that hole by the aerial for? Driver cooling?
Ozan
Ozan
it's for driver cooling as it's now hot in Baku.
dans79
267
So another new front wing, this one with taller strakes?
202 105 104 9 9 7
Atticus
Atticus
Measuring distance covered during the first 5s of the race shows that Raikkonen had an average start, on par with Rosberg. Hamilton, on the other hand, had the 5th worst of the field after Hulkenberg, the two Haas and Magnussen.
Vettel had the overall best.
The F1 Formbook - https://thef1formbook.wordpress.com/
Performance analysis of F1 race weekends based on raw official data
NL_Fer
NL_Fer
82
Can somebody please explain why the Mercedes has such great pace on prime tyres? Other teams are still freightent about it, when they create their strategies.
diego.liv
diego.liv
Something related to NL_Fer. In order to mantain the correct level of tyre pressure, do they have to keep a (sort of) fixed pace? Or pressure will adjust itself thanks to the internal flows created through the rims? i.e. a faster corner won't rise the pressure too much, cause the more energy created will travel differently through the rims
ClarkBT11
graham.reeds wrote:
Ferraripilot wrote:I've always been certain all formula 1 wheels for some time have been of forged magnesium, but with Mercedes' heat sink wheel design they've used since W04, I can't see how such a design could be forged via the traditional process. Could it be possible they are using cast magnesium? If so, the wheel would be about a kilo heavier. If not, anyone care to explain how such a design could possibly be forged.
Either Mercedes are employing a graduate of Hogwarts to put grooves in their wheels or they use a lathe.
It's just a normal wheel that's been lathed.
My guess would be a water jet cutter.
https://en.m.wikipedia.org/wiki/Water_jet_cutter
basti313
basti313
32
Are there any pictures of possible changes from Friday to Saturday?
I still wonder, what they changed on the cars, that made the car undrivable for Ham on Saturday and which are not allowed to be told by Ham.
Tire pressure and camber is limited. Brake temps have a broad range, suspension is always as soft as possible on the Merc...what else can destroy the feeling under breaking?
The only thing that would fit for me at the moment is a change in the brake supplier and after Hockenheim no one is allowed to talk about that. Is this reasonable?
Don`t russel the hamster!
erikejw
erikejw
Software problem for the Mercs in the race? Both Nico and Lewis had problem with derating, Lewis a few laps earlier.
My theory is new software that kicked in during the pitstops and there was a bug in it. Max speed like quali mode on the in and outlap but the engine continued to derate.
So either of them did anything wrong with settings. It could be helped by some weird sequence of settings by luck or wait for a time delay when the software resets itselfs away from those special parameters used. Maybe a safety action if battery is too loo for long.
This is just a theory. Can anyone confirm or deny the possibility?
Shrieker
Nice theory, went into the race thread to look for this, only to find 5 y/o's yelling at each other. Although i should admit i was guilty of the same in the good old days, not so blatant though.
-Atatürk
OO7
OO7
171
Shrieker wrote:Nice theory, went into the race thread to look for this, only to find 5 y/o's yelling at each other. Although i should admit i was guilty of the same in the good old days, not so blatant though.
Hence the name 'Shrieker'. :D
De Jokke
erikejw wrote:Software problem for the Mercs in the race? Both Nico and Lewis had problem with derating, Lewis a few laps earlier.
What suprises me the most is that it rectified itself with 10 laps to go on Lewis' car. Either you are in a faulty mode or not... very suspicious...
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
