2016 Hungarian Grand Prix - Hungaroring, 22-24 July
cooken
cooken
Re: 2016 Hungarian Grand Prix - Hungaroring, 22-24 July
Folks, I recommend you watch the onboard lap in high quality, and focus on his strong wheel. As he enters the yellow segment, there is a flashing led above his left hand. Listen to the engine while looking at the light, you can see it just after the left, and it goes out just before apex of the next right. Very hard to discern any amount of lift except for the initial bit prior to the left.
Actually it appears the only lighting he did at all was just BEFORE he even got to the first yellow.
FoxHound
55
Shrieker wrote:Because it was the corner just before Alonso spun...
Just after no? He already passed Alonso's car the corner previous....
JET set
TAG
I don't have a problem with Rosberg being allowed to keep pole, thank god the situation wasn't reversed and it was Lewis going purple under yellow. :)
माकडाच्या हाती कोलीत
dans79
267
FoxHound wrote: The second one being for the incident Rosberg had already passed? And it was a right hander which is pretty low speed, if this is the "second one" you a referring to?
Nico hadn't passed it, he got yellows before turn 8 and 9, Alonso spun at the exit of turn 9.
201 105 104 9 9 7
cooken
cooken
Umm no. Alo spun after that right hander.
FoxHound
55
Right ok.
JET set
RedNEO
40
That's a question that has no answer. A lift is a lift, how are you supposed to know the difference between a 5 tenths lift and 2 tenths lift in real time?
dans79
267
The drivers have stated several times that the wheel tells them how up/down they are compared to previous laps in real time.
201 105 104 9 9 7
RedNEO
40
Does it tell them how long to take there foot off the gas too? Comon this is just a steering wheel not a JARVIS from ironman
siskue2005
70
TAG wrote:I don't have a problem with Rosberg being allowed to keep pole, thank god the situation wasn't reversed and it was Lewis going purple under yellow. :)
Then he surely would have been to send to back of the grid, and we wont have had these discussion :D
He could have taken the engine penalty here then :P
siskue2005
70
FoxHound wrote:Right ok.
ok. so what is your take now?
LionKing
LionKing
dans79 wrote: The drivers have stated several times that the wheel tells them how up/down they are compared to previous laps in real time.
What if it is drying circuit that is getting faster and faster? The lap time being faster alone does not mean a driver did not lift.
The only way to judge that is from the telemetry of the car.
cooken
cooken
Problem is that it's highly dependent on track location. His lift was before two slow corners, and the second didn't lead into any kind of straight. For this reason you can't define it using a time loss.
proteus
22
siskue2005 wrote:
proteus wrote:He drove into the sector with yelow flag, he slowed down a bit (u can hear the engine rewing down) and continuied flat out again with no yelows in sight. As i saw it, yelows were only on for that fraction of a second and he fulfilled that fraction, from than on there was no yelow anymore and as i understand no need for slowing down or being 0.5sec slower. U can see it at 0:50 on F1.com: http://www.formula1.com/en/video/2016/7 ... _2016.html
The yelow was not on long enough to count as a whole sector.
There were double yellows even after the corner!
https://lh3.googleusercontent.com/-lmrd ... OSFAIL.jpg
Well spotted, i missed the second mark.
RZS10
359
There wasn't even an investigation. Rosberg stays on pole.
edit: not true ... they decided to investigate afterall...took em long enough
