Scuderia Ferrari SF70H
Re: Scuderia Ferrari SF70H
This is parts being elastic, not being moved by driver like DRS, F-duct or being influential to aero platform like FRIC... Other than failing to pass regulated tests (which they obviously did) FIA has no reason or cause to ban this. They could by simply changing the regulations, but it's not likely to happen this season without safety concerns. And I honestly can't see any...
bhall II wrote:
11 Apr 2017, 21:54
I think what we see in that GIF are sparks being deflected by the rear wheel's bow wave.
Most definitely. But it works in conjunction with diffuser - it sucks the air towards it and tyres push it in there as well. Of this I have no doubt...
#Aerogimli
bhall II
bhall II
473
Yes, but to make any sort of quantitative assessment of local air flow based upon the trajectory of those sparks, given the fact that they've gotta go somewhere, seems odd to me. Some are deflected inside, some are deflected outside, and some of them even get run over.
roon
roon
412
bhall II wrote:
12 Apr 2017, 22:21
-Pastor Maldonado on approaching other cars on a racetrack.
But in all seriousness, I think it's time to address the really important question: does downforce increase when driving through sparks?
f1316
f1316
78
roon wrote:
12 Apr 2017, 23:16
bhall II wrote:
12 Apr 2017, 22:21
Given you have to be close to another car in order to drive through sparks, you would imagine the exact opposite :wink: :D
bonjon1979
bonjon1979
30
bhall II wrote:
11 Apr 2017, 21:54
___________
http://i.imgur.com/XOgj9jO.gif
via American Physical Society
https://twitter.com/FiftyBuckss/status/ ... 8364706816
If you watch closely, you'll see that one of the sparks is deflected inward to the diffuser at the exact moment part of the floor flexes down. I suspect there could be a lot of questions about this to come.
LookBackTime
LookBackTime
472
hamilton#1
hamilton#1
Henk wrote:
12 Apr 2017, 01:20
f1316 wrote:
11 Apr 2017, 14:43
What are the load tests on the floor? And how are they applied?
Ultimately, a front wing is legal if it passes the necessary tests - even if during the race we see footage of it flexing like mad; Red Bull proved that multiple times.
I suspect it will be the same with the floor (and potentially FIA will look to introduce stronger loads if they don't like what's happening) but must admit I don't know what kind of tests the floor undergoes.
I don't know if they test the floor either but any moveable earo device other than DRS is not allowed. This is how they banned FRIC and how they clarified the rules on suspension. Presumably the FIA can just ban this overnight.
The floor is tested at the front of the floor and near the rear tyres, but this is no rule. So if they want to, the FIA can measure de loads on the floor at any point at any time.
ScrewCaptain27
577
Via AMuS:
- Serj Tankian
ferkan
ferkan
31
Updated FW
DiogoBrand
73
Mercedes style tunnel?
Ooh! That slot was definitely designed to flex! They used a metal bit instead of carbon at the base of it. Not to mention it is an outright cantilever. It probably opens up to change the size and strength of the vortex at different speeds and yaw.. Very clever.
I hope mercedes copies this quickly.
Henk
Henk
Vanja #66 wrote:
12 Apr 2017, 20:59
The front wing loads test was changed based on front wings being too elastic. The FIA can ban this by just stating that they suspect it gives an earo gain and then change the load test. If there is no earo gain Ferrari also wouldn't mind changing it.
Come to think of it, they should use this rule to ban the T-wing by just increasing the load to the heaviest thing they can attach to it.
marvin78
marvin78
What's bad with the T-Wing?
