Force India VJM10 Mercedes
charly0418
charly0418
Re: Force India VJM10 Mercedes
New sidepods arrived mid FP1
https://twitter.com/Jamesallenonf1/stat ... 6627117061
They'll probably start using them tomorrow for FP3, doubt they can install them for FP2
NAPI10
NAPI10
Looking quick in FP1; hope they can shed some more time with slim side pods.
ScrewCaptain27
577
Via FormulaPassion.it
- Serj Tankian
NAPI10
NAPI10
Any idea if FI tried new sidepods at Canada?
Samraj_official
NAPI10 wrote:
12 Jun 2017, 15:28
I Don't think so,they were basically the same.
Low-downforce rear wing for Baku
avatar
avatar
Okay, I've had a search and can't find any comments on it yet, so here goes:
Just watching some of FP3 at Baku and from the on-board shots, the front wishbones on the FI /appear/ to be turning with the steering.
Particularly notable on the switchback in this FP2 clip:
http://www.youtube.com/watch?v=DXsnFfOpzMY&t=0m57s
It's the first time I've noticed it. Not seen it on other cars & the pre-season comments about the nose hump to the effect "we're exploiting an area of the rules to help with mech. grip" make me wonder.
I'm totally open to it just be a combination of lighting and "normal" suspension geometry/travel, but something looks odd to me.
Thoughts?
Just looks like normal compression/extension on roll to me to be honest. The rules about wishbone fixings are fairly robust.
NAPI10
NAPI10
New Side pods is still a mystery....are they going to introduce at Silverstone?
Samraj_official
NAPI10 wrote:New Side pods is still a mystery....are they going to introduce at Silverstone?
No idea,can someone offer some source into upcoming FI updates?
They haven't changed anything drastically or visibly since the start of the season
Caito
Caito
ScrewCaptain27 wrote:
26 May 2017, 19:30
Pushrod rocker detail via @ScarbsTech:
https://uploads.tapatalk-cdn.com/201705 ... dbd35e.jpg
Can anyone identify what is in the outside perimeter of the rose joint? Looks like a needle thrust bearing, but I don't think it's one as there are no (as far as I know) thrust forces on the rocker arm
Come back 747, we miss you!!
scarbs
scarbs
393
It's a thrust bearing exactly as you described...
Caito
Caito
scarbs wrote:
29 Jun 2017, 12:33
What for? Does the pushrod goes there or on the eyelet without thrust bearing?
I'm not understanding where does the axial force comes from.
Thanks!
scarbs
scarbs
393
Like all F1 cars, the other end of the push rod mounts on the upright, not the lower wishbone. It is offset from the steering axis, so the push rod moves with steering angle. This puts the offset load into the top mount, hence the thrust bearing.
Egroeg
Egroeg
Sphericals take axial thrust loads all the time so I don't think it's for that, for example when you have the pushrod mounted on the wishbone, the wishbone spherical takes an axial thrust load - either from braking or the vertical load, depending on what orientation is chosen.
I think it's more likely just a low friction version of the 'low tech' way you stop a pushrod (which has sphericals both ends) rotating along its axis and rubbing metal-to-metal on the rocker or upright. Quite frequently you'll see o-rings put either side of the spherical to pinch up the pushrod a bit which controls the movement but does add friction, this is a bit more F1!
