Scuderia Ferrari SF70H
CriXus
CriXus
95
Re: Scuderia Ferrari SF70H
According to f1analisitechnica.com "The cooling ducts in the two ears are fed freshly with the Energy Recovery System radiator, which has undergone an important layout (and typology) modification, and has allowed the Italian team engineers to redistribute the weight in the back of the car."
http://www.f1analisitecnica.com/2017/09 ... cchie.html
“The reasonable man adapts himself to the world: the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man.” - George Bernard Shaw
Tighter at the back?
ScrewCaptain27
577
Via AMuS
- Serj Tankian
Fede90
Fede90
This new flap in front of the barge boards seems to be going more forward than on all the other cars. Loophole?
#Aerogimli
This airbox is even thicker than i thought at first impression :shock:
Ps: with this airbox the mid-wing is gone.
Which mid wing do you mean? The black one behind the roll hoop camera?
#Aerogimli
Gilles27Kimi7
Gilles27Kimi7
25
Yes, that one
F1NAC
164
Vanja #66 wrote:
29 Sep 2017, 11:08
https://cdn-2.motorsport.com/images/mgl ... h-side.jpg
it looks like this new flap is energizing vortex @bargeboards ?
If you look closely you'll see it changes the direction of where it sends the airflow. Upper part of it is just another flap in those barge boards, with a slot energizing the boundary layer on the inner side to keep it attached. Then in the middle it start going outboard, to send the lower layers of airflow coming under the nose outboard and towards those many slots and leading edges creating a bit of downforce. Basically, it brings more clean and high energy airflow exactly where it's needed. Almost text-book stuff really :D
#Aerogimli
ScrewCaptain27
577
Finally some images of the PU from the sides and from behind:
- Serj Tankian
ScrewCaptain27
577
Via FormulaPassion.it:
- Serj Tankian
Xwang
Xwang
29
Does Ferrari have the gearbox splitted in two "skins" like Mercedes with the internal one the only which cannot be changed before having completed 6 races and the external one that to which suspensions arms are attacked?
F1NAC
164
Xwang wrote:
01 Oct 2017, 12:27
yes.
