Mercedes AMG F1 W09 EQ Power+
Re: Mercedes AMG F1 W09 EQ Power+
Post by godlameroso » Sat Mar 10, 2018 1:15 am
The diffuser central section looks like the underside of a seagull(the bird).
Blaze1
52
Post by Blaze1 » Sat Mar 10, 2018 1:54 am
It does doesn't it! :lol:
Blaze1
52
Post by Blaze1 » Sat Mar 10, 2018 1:55 am
The Mercedes diffuser is very interesting because all of the vanes have been split into two (a forward and aft section). I don't recall seeing that before.
Post by godlameroso » Sat Mar 10, 2018 4:56 am
The way the edges of the diffuser curl in reminds me of the wings of this here fella, just upside down
Post by PlatinumZealot » Sat Mar 10, 2018 2:06 pm
https://cdn-5.motorsport.com/images/mgl ... ffuser.jpg
Red Bull was the first to do that a few years ago. Granted they didnt have that many vanes.
"The true champions are also great men. They are capable of making difficult decisions, of admitting their mistakes and of pushing harder than before when they get up from a fall."
- Ferrari chairman Sergio Marchionne
TAG
80
Post by TAG » Sun Mar 11, 2018 2:40 am
Good interview with Aldo Costa by Will Buxton
5 Time WDC Party Mode ¯\_(ツ)_/¯
F1Krof
42
Post by F1Krof » Sun Mar 11, 2018 7:59 pm
https://youtu.be/zVMiA1PhW_E
I keep saying again. This year they seem unusually calm and confident? Either they've --- up or created something unheard. Toto's very calm as well. What do you think is going on behind the scene?
Post by PlatinumZealot » Sun Mar 11, 2018 10:39 pm
W09
W08
Woah. The rear suspension is unusual. The top control arm is just tiny bit longer with a pick-up point of about 20mm higher than last year. The in-board pick-up points are also mounted higher giving a gentler angle. The roll centre should be higher by doing this, but no point in talking about roll-centre in modern F1 - doesn't matter much.
The real important thing is that the higher and more horizontal wishbones, indicate that they want to keep the contact patch more level by reducing the camber change in squat and bump.
Speaking of squat the plane made by each top wishbone is also less sloped forward. This means there is less "anti-squat" dialed into the suspension. Means a more pliable suspension movement. The Mercedes engineers felt that the new car has a good dynamic weight distribution and stable aerodynamics so they are expecting less rearward weight transfer.
I think these developments are purely for tyre life purposes. The new tyres are much softer this year. This might be the influence of James Allison, who has made cars that were very gentle on their rear tyres.
The other teams like Mclaren, Ferrari have the upper joint closer the chassis with a steeper inclination of the control arm. This inducing a bigger camber change when the suspension is compressed. Good performance in the corners but in squat when accelerating out of the corner the contact patch is smaller heating up the tyres more.
I expect Mercedes to have slower tyre warm up this year but monstrous stint lengths. No problem when you are racing from the front.
astracrazy
50
Post by astracrazy » Sun Mar 11, 2018 11:19 pm
If a teams f’d up you would know by there track running. Mclaren recently or red bull a few years ago with over heating etc
I say confident. If your cars performing at the top (3) with no problems then you can be. I guess they know if they have fixed the diva issues which it would suggest they have. They are meant to have improved the engine again too.
ScrewCaptain27
391
Post by ScrewCaptain27 » Mon Mar 12, 2018 8:10 pm
Cooling outlet behind the Halo:
Via Motorsport.com
- Serj Tankian
Post by godlameroso » Mon Mar 12, 2018 10:12 pm
They moved the cooling outlets in the rear, they're above the lower wishbone this year, no doubt to open up the space on the top side of the diffuser.
Maritimer
Post by Maritimer » Mon Mar 12, 2018 11:17 pm
What kind of velocity does the air coming out of the cooling exits have? Is there any advantage to having them exit over the diffuser like that? Other than simplicity.
Post by PhillipM » Tue Mar 13, 2018 12:01 am
Slower than the air around the sidepods.
Kalsi
19
Post by Kalsi » Tue Mar 13, 2018 12:18 am
Sorry if this was posted before but...
CircusF1 claiming W09 not only retained it`s wheelbase, but it increased instead by another 63mm taking the mercedes to a whopping 3.823mm.
SF71-H on the other hand should be 120mm longer than it`s predecessor... taking the ferrari 2018 car to 3.714mm.
Here is the source link: http://www.circusf1.com/2018/03/le-f1-2 ... 9-60mm.php
In Short:
W08 = 3,760 mm >>>>> +63mm >>>>> W09 = 3,823mm
SF70-H = ‎3,594 mm >>>>> +120mm >>>>> SF71-H = 3,714mm
Notice how W08 was still longer than this year SF71-H
Anyone can confirm?
Post by Just_a_fan » Tue Mar 13, 2018 12:28 am
The air will be hot and thus lower density than ambient. Although the airflow might be slower than that immediately around the openings, the temperature induced lower density might allow the same effect i.e. to reduce the pressure difference above and below the floor at the diffuser's exit. The diffuser's job is to bring the pressure of the air exiting from below the floor back to the same as the pressure around the car (ambient). By having fast air moving over the diffuser, you reduce the pressure differences between the flows above/below the floor and there is then less drag as the flows merge. Fast air is lower pressure, as is hot air. So having hot air means the same benefits as "fast air". The teams have to dump the hot air somewhere and doing it this way helps the aero performance. That's my entirely amateur "first guess". :oops:
Oh, and having hot air blow below the rear wing would give an enhanced pressure difference across the wing too - more downforce at a given speed. Although I doubt this effect is what they're chasing here.
Turbo says "Dumpster sounds so much more classy. It's the diamond of the cesspools."
