Scuderia Ferrari SF71H
roon
377
Re: Scuderia Ferrari SF71H
Post by roon » Fri Sep 14, 2018 11:09 pm
siskue2005 wrote:
Thu Sep 13, 2018 3:13 pm
Better picture
Notice that it does not immediately obstruct the camera, there is a hole cut out in the housing. Other teams use similar devices.
Morteza wrote:
Thu Sep 13, 2018 2:46 pm
This cooler is also new
Via AMuS
Both examples would block line-of-sight between camera and steering wheel.
M840TR
281
Post by M840TR » Sat Sep 15, 2018 9:12 am
Tea-tray extension. Note similar guide vanes to direct air under the bargeboards.
Floor.
Rear suspension.
Post by zioture » Sat Sep 15, 2018 10:12 am
roon
377
Post by roon » Sat Sep 15, 2018 9:40 pm
SF71H bodywork relatively simple compared to the rest of the field *except* for the edges of the floor, where they have surpassed McLaren, even.
ScrewCaptain27
468
Post by ScrewCaptain27 » Sun Sep 16, 2018 10:19 am
Some flow-viz pics from Racecar Engineering:
- Serj Tankian
Dipesh1995
78
Post by Dipesh1995 » Sun Sep 16, 2018 11:47 am
Bit of trailing-edge region flow separation showing the rw flap is running at/very close to its limit in terms of usable AoA.
roon
377
Post by roon » Wed Sep 19, 2018 1:03 am
Looks like a near vertical vortex forms inside the endplate, sprouting from the first main louvre.
M840TR
281
Post by M840TR » Wed Sep 19, 2018 5:30 am
https://pbs.twimg.com/media/DnC4CI0X4AA9rMs.jpg:large
https://i.imgur.com/I3NELfp.jpg
Vortexes form at the tip of a surface though. This highlighted area just indicates laminar upwash.
M840TR
281
Post by M840TR » Wed Sep 19, 2018 11:20 am
dfegan358
-2
Post by dfegan358 » Fri Sep 21, 2018 12:21 am
Any updates planned for Russia?
Mercedes made a big step in Singapore. Ferrari need to respond!
timbo
Post by timbo » Sat Sep 22, 2018 7:41 am
Any updates they present in Russia are a product of weeks (if not months) of research and manufacture. It is impossible to "respond" with updates.
F1NAC
154
Post by F1NAC » Wed Sep 26, 2018 2:06 pm
HALO disassembled
Post by MtthsMlw » Wed Sep 26, 2018 7:13 pm
AMuS
roon
377
Post by roon » Thu Sep 27, 2018 12:40 am
AMuS
I bet those fins work pretty well. Considering they would fill pretty much all of the small gap between the brake shroud drums and the wheel, and spin upwards of 3k RPM. I'm still curious as to whether ambient temperature air or heated brake disc exhaust flows through this small gap. Brake drum/cake tin designs seem to vary quite a lot, and sometimes it looks like ambient air is being ducted in, and other times it looks like brake disc exhaust is being vented there. Usually people say they're trying to heat the wheels in order to heat the tires, others say they're trying to cool the tires by cooling the wheels.
zibby43
124
Post by zibby43 » Thu Sep 27, 2018 8:53 am
