Mercedes AMG F1 W09 EQ Power+
Big Tea
Re: Mercedes AMG F1 W09 EQ Power+
jh199 wrote:
02 Oct 2018, 00:12
PhillipM wrote:
01 Oct 2018, 23:37
JasonF1 wrote:
01 Oct 2018, 20:21
Could Mercedes be using a passive rear wheel steering?
All teams use passive rear wheel steering, have for decades
How? Suspension geometry turning the wheels in compression or something more devious? I've never heard of this before, at least, nothing credible thus far
Could this be in the same vein as the Mclaren 3rd peddle?
Drag the left side, it turns left. Drive the right side harder, it turns left
Just_a_fan wrote:
01 Oct 2018, 18:25
01 Oct 2018, 16:30
I have my reason why I think it is designed for heating.. I am glad to be proven wrong, but lets work it out scientifically.
https://www.autosport.com/f1/news/13881 ... d-mercedes
Erm... that's just an article from a Journo. Are you new here? haha.
But seriously though, there are easier ways to cool the rim.
jh199
32
PhillipM wrote:
02 Oct 2018, 00:22
jh199 wrote:
02 Oct 2018, 00:12
That and changes under load. It's not exactly rocket science.
Whoops, completely read over 'passive' in your post #-o. I thought you were implying more of a conspiracy.
Anyway, the only thing I would think they could get away with is letting the front of the gearbox tilt outwards a bit mid-corner. With the suspension arms mounted on the gearbox, an outward tilt could pull the front of the rear wheel inboards. Helping the car rotate in the same why supercar rear wheel steering works. This would, I'd think, make the car incredibly unstable at the rear though as the cornering speed increases. I'm still convinced that this rumor is just hot air though. Mercedes has just been getting their setups right on an already near perfect car.
garyjpaterson
Contact:
jh199 wrote:
02 Oct 2018, 03:57
Wtf!? A tilting gearbox? wow.
Whats wrong with just designing in some bumpsteer? Its so simple and adjustable...
This topic does not extend to conjecture about Ferrari's "dissapeared performance". We will remove any message which does not has the W09's hardware at its core of the subject.
jh199
32
garyjpaterson wrote:
02 Oct 2018, 13:01
jh199 wrote:
02 Oct 2018, 03:57
Yea its totally riciculous but Ive heard worse before. I figured if articles are going to pop up about this rear wheel steering there must be something more devious than just some simple suspension geometry tricks.
jh199 wrote:
02 Oct 2018, 13:24
02 Oct 2018, 13:01
jh199 wrote:
02 Oct 2018, 03:57
I think the article is more from a high concentration of NaCl in the authors body
Jolle
132
Looking at the rear of the W09 it doesn't look like they did something with a moving gearbox but rather something quite simple. It looks like, same as at the front, they gave mechanical grip and the geometry of the wishbones, pull and pushrods, etc, a less compromised design then other teams, allowing them to be more precise and have a softer rear, helping with low speed grip.
jh199 wrote:
02 Oct 2018, 00:12
No point, you'd just make the mountings for the tie rods linked together and then make the thing compliant, you don't need anything silly like 'tilting gearboxes' or the other stuff the other author was coming up with.
This is something that keeps getting dredged up by clueless hack 'tech bloggers' every year - we had the exact same accusation at the beginning of the year and last year. They never seem to realise everyone is using passive rear steering.
02 Oct 2018, 00:57
Just_a_fan wrote:
01 Oct 2018, 18:25
01 Oct 2018, 16:30
Prove it's for heating the tyres if you're so sure..
:roll:
jh199
32
PhillipM wrote:
02 Oct 2018, 16:46
jh199 wrote:
02 Oct 2018, 00:12
True, im not saying that twisting the gearbox is whats going on or even something that is feasible. I was thinking anything that would allow the forward tie rods to push and pull the tires a bit would allow rotation around a pivot in the upright. I figured that since the tie rods can be mounted on the gearbox, let the gearbox rotate a bit and allow these tie rods to be moved inboard and outboard, effectively steering the rear wheels ever so slightly.
But I vote we move on and pretend I never even mentioned this :D
Big Tea
So anyone know for sure 'split torque' is not legal?
Driving the outside wheel more than the inside wheel could be a considerable advantage on tight corners, not sure about in general though
OO7
OO7
171
Isn't that exactly what all the differentials up and down the grid have been doing for a very long time now?
Big Tea
Blaze1 wrote:
02 Oct 2018, 18:37
I believe so, is that not 'steering' (assist) with the rear wheels?
Dipesh1995
104
