Because when you set up a car at the track you don't have unlimited adjustability. at some point a design change is required, and that change might help one driver while hindering the other.
From Mark Hughes:
Where did you read that? I never said that...Just_a_fan wrote: ↑10 Oct 2018, 21:44The cars aren't built to a specific driver. The suspension can be tuned as can downforce balance but that's it really. Bottas's car coupd be set up for him just Hamilton's cam be for him.
Likely is that Hamilton has just learnt to look after his tyres. Part of being a top driver is being able to adjust to changes whilst maintaining pace.
Of course. However, there isn't much reason not to let Bottas run the older parts that, apparently, worked better for him.
Yes, but now you are getting into the issue of old parts not being optimized to work with the new ones, and you get a knock on effect the more out of sync you are with the latest round of parts.wesley123 wrote: ↑11 Oct 2018, 08:51Of course. However, there isn't much reason not to let Bottas run the older parts that, apparently, worked better for him.
The investigation has concluded that Mercedes' design has different intentions to the 2012 Red Bull systemFlanker27 wrote: ↑17 Oct 2018, 21:01FIA is always more ridicolous...
https://www.autosport.com/f1/news/13944 ... rari-query
RB illegal in 2012, Mercedes legal in 2018...
Yes, the car position on the track map is wrong but numbers are correct. So just before the 130r this is what it looked like:dans79 wrote: ↑10 Oct 2018, 14:42There is a huge difference between posting screenshots of the timing pages which match the official timing reports versus the "real time" map that is often wrong and glitchy as hell.siskue2005 wrote: ↑10 Oct 2018, 14:35the app is great, Juzh posts telemetry from it. check italian gp thread for videos of the app
What were the intentions of Red Bull and Mercedes? I read this article but i would like to be clarified.mixmentzos wrote: ↑17 Oct 2018, 21:05The investigation has concluded that Mercedes' design has different intentions to the 2012 Red Bull systemFlanker27 wrote: ↑17 Oct 2018, 21:01FIA is always more ridicolous...
In short Redbull used it as a aero device and Merc is not using it as a aero device.santos wrote: ↑18 Oct 2018, 15:00What were the intentions of Red Bull and Mercedes? I read this article but i would like to be clarified.mixmentzos wrote: ↑17 Oct 2018, 21:05The investigation has concluded that Mercedes' design has different intentions to the 2012 Red Bull systemFlanker27 wrote: ↑17 Oct 2018, 21:01FIA is always more ridicolous...
