Mercedes AMG F1 W09 EQ Power+
dans79
267
Re: Mercedes AMG F1 W09 EQ Power+
here is the tweet showing both side of the Merc wheels.
https://twitter.com/AlbertFabrega/statu ... 6250705920
197 104 103 7
dans79
267
Phil wrote:
25 Oct 2018, 21:14
The FIA didnt “decide” anything. They gave an opinion. Nothing more. If there is a post race protest, it’s the stewarts that male the verdict, not the FIA.
Yes but a stewards decision and be contested and then it goes to the FIA if memory serves!
197 104 103 7
RZS10
359
please ignore the quality of the drawing
am i mistaken to think that the area between the wheel hub (green) and the rim would be sealed by the nut and the hub (pic 1 and 2 in red) if it wasn't for the holes?
or do the holes marked with yellow go somewhere? those appear to be in the nuts
could it be that the holes (pink in pic 1) are connected to the other holes inside the rim (in pink) ?
dans79
267
RZS10 wrote:
25 Oct 2018, 21:28
The holes inside the hub area look to pass through into the cavity in the spokes. Take a look at the tweet i posted above.
197 104 103 7
RZS10
359
oh yea that's in the pic ... lol :oops:
red is that connection ... the holes marked green have to have some purpose ... could they potentially connect to the other ones inside the rim ...meaning that the rim would be partially hollow
matt_b
matt_b
Good listen from Scarbs about these rims.
The pink holes in pic 1 (top left) are the drive holes - the pegs in the face of the wheel engage in those to transmit torque to the wheel.
227
Why i disagree with scarbs is blowing hot air through the wheels cannot keep heat away from them. You are actually putting heat into them. What he is saying would make sense if the wheels were already hot, and fresh cool air is being blown in to drive away that heat.
Cooling of the wheel is better done by having a brake duct that simply diverts air into the rim annuls.
zibby43
zibby43
613
Mercedes given the all-clear to run the wheels as designed.
https://twitter.com/AlbertFabrega/statu ... 4150226944
dans79
267
zibby43 wrote:
26 Oct 2018, 01:07
Some people are going to be really unhappy about this!
197 104 103 7
seventhsin
The stewards decision focuses nearly entirely on the holes in the spacer and not the holes in the wheel. I think that they're creating a low pressure area inside the wheel hub via the rotation of the holes that pass through the spokes.
This in turn draws air through the small holes in the spacer, which gets its air from the drive lug holes. I'd be willing to bet if we saw behind that spacer we'd see a number of holes there divisible by the number of spokes.
Sent from my SM-N960F using Tapatalk
djos
113
Seems like a reasonable decision to me, any aero benefits would have to extremely tiny I'd have thought.
"In downforce we trust"
Blaze1 wrote:
25 Oct 2018, 20:43
25 Oct 2018, 11:33
We need to see the rear wheel hubs...
I dont see where the air comes from to go into the middle of the rim... The outer discharge point looks to shoot air tangentially. . Not sure if into the spokes or the barrel of the wheel... Need a side view.
Any more ideas?
https://cdn-2.motorsport.com/images/mgl ... -rim-1.jpg
Looks like a different material lines inside the wheel where the holes are. For insulation purposes of course. This thing is designed to prevent heat transfer to the centre part of the wheel.
https://pbs.twimg.com/media/DqUEXPIU4AAx3OR.jpg
The air comes from the 24 circumferential holes on the hub.
EDIT:
Is it possible that part of the hub (the part with the 24 circumferential holes) can move inwards and outwards, either when the wheel is attached to the hub, thus revealing and locating the thermal management holes or while the wheel or while the wheel is attached based on temperature? (I don't know if the regs would allow this however.
Those holes are on every car wheel and are pretty much blocked off by the flange of the wheel when mounted though.
In mercedes case u could be right hoewever. These are even more holes on top of the ones inside the cavity.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
The smake perforated holes on the plate are restrictors.. Or else it would be full open bore..
LxVxFxHxN
gandharva
252
zibby43 wrote:
26 Oct 2018, 01:07
So, everyone will run such systems in the near future. Going to be fun next year when 30% of the solutions are then declared illegal because they could have aero importance.
