Mercedes-AMG F1 W10 EQ Power+
Re: Mercedes-AMG F1 W10 EQ Power+
Via @AlbertFabrega
dans79
267
What are those massive bulbs on the sides of the rear wing uprights?
197 104 103 7
mantikos
mantikos
35
The floor area is massive and the side pods miniscule
dans79 wrote:
18 Feb 2019, 16:31
You mean on the endplates? That's testing equipment, probably collecting data and measuring flow.
mantikos
mantikos
35
dans79 wrote:
18 Feb 2019, 16:31
Temporary sensor and data logger housings to house testing apparatus - will be gone after testing
dans79
267
turbof1 wrote:
18 Feb 2019, 16:33
dans79 wrote:
18 Feb 2019, 16:31
I was pretty sure that it was for testing, but it's not readily apparent what types of readings its taking.
197 104 103 7
GrandAxe
GrandAxe
dans79 wrote:
18 Feb 2019, 16:55
turbof1 wrote:
18 Feb 2019, 16:33
dans79 wrote:
18 Feb 2019, 16:31
Could be wind velocity/pressure and temperature gradients over the wide band containing diffuser, exhaust, rear wheels and rear wing. Maybe some sort of laser system. I'm just guessing.
mantikos
mantikos
35
dans79 wrote:
18 Feb 2019, 16:55
turbof1 wrote:
18 Feb 2019, 16:33
dans79 wrote:
18 Feb 2019, 16:31
Data logger
jjn9128
770
dans79 wrote:
18 Feb 2019, 16:31
Qualcomm wi-fi transmitters for all the extra data they're collecting.
#aerogandalf
zibby43
zibby43
613
Looks like flow-viz on the front wing. Love these overhead shots.
zibby43 wrote:
18 Feb 2019, 22:48
Indeed so. Look at how the airflow on top of the first element is flowing outwards towards the endplate.
FMP
FMP
Just_a_fan wrote:
18 Feb 2019, 23:21
zibby43 wrote:
18 Feb 2019, 22:48
Very interesting actually. Need to look at other angles to understand what forces the air flow that way. Looks unnatural from this angle.
zibby43
zibby43
613
Just_a_fan wrote:
18 Feb 2019, 23:21
zibby43 wrote:
18 Feb 2019, 22:48
Good spot! Noticed that as well. Looks like with the inward curve of the end plate, Merc is getting a stronger, jet nozzle sprayer effect going, pushing the air out and across the front tires.
