Williams FW42
ScrewCaptain27
578
Re: Williams FW42
Manoah2u wrote:
Wed Feb 27, 2019 10:07 am
DiogoBrand wrote:
Wed Feb 27, 2019 4:24 am
roon wrote:
Wed Feb 27, 2019 2:57 am
In previous seasons they've mounted testing hardware there. If not that, and if legal, I wonder if they would reuse a monocoque from last season.
https://www.thisisf1.com/wp-content/upl ... AArJDw.jpg
https://imgr3.auto-motor-und-sport.de/S ... 149188.jpg
At first I tought so as well, and it would be legal to use the same monocoque since there are no rule changes like the addition of the Halo. But then I went looking to see if there were any aero bits attached there, and what I found is that the same attachment points were there last year, but they were also left blank.
https://cdn-7.motorsport.com/images/mgl ... detail.jpg
so could that actually mean they're using the same monocoque design for a 3rd season now?
or even worse - could they be using the literal same monocoque for the 3rd season? so one that was made in 2017?
No, may be similar to the 2018 one but it is new. Definitely NOT the 2017 chassis, the sidepods/impact structures and bulkhead are completely different.
- Serj Tankian
Re: Williams FW42
RZS10
223
Re: Williams FW42
Williams got informed by the FIA that their mirrors are illegal and have to be changed for Melbourne (AMuS)
Moctecus
Re: Williams FW42
New front wing:
roon
roon
449
Re: Williams FW42
roadie wrote:
Tue Feb 26, 2019 11:41 pm
Anyone know why the front suspension is so much more bulky than other teams running the raised wishbones?
Maybe there is some aero advantage. Reminiscent of how Alfa put bulky covers over their Ferrari suspension arms (rear upper arms):
cravenciak
cravenciak
Re: Williams FW42
237
Re: Williams FW42
They dont want to generate vortices with the upper wishbone joint. Likewise for ferrari with the rear wishbones. So they bulk and round these areas to have smoother flow. Also, these elements have an aerodynamic role. They also pitch a lot relative to the rest of the car, and rounder and bigger edges will make them have smoother and more predictable stall characteristics. So in essence these bulky parts make the car more predictable overall (the transient aero loads), while having cleaner flow downstream.
FW17
237
Re: Williams FW42
cravenciak wrote:
Thu Feb 28, 2019 11:49 pm
https://abload.de/img/fw42fwmxj33.png
Is the new one a lower downforce spec?
bosyber
bosyber
Re: Williams FW42
Isn't the thickness simply because there is a minimum ratio of thickness to 'width' for these suspension components, which means that if you want an airfoil shape/width, it will have to be thicker too?
Re: Williams FW42
Via @AlbertFabrega
desl
desl
38
Re: Williams FW42
Is that a new beam wing? :D
Re: Williams FW42
desl wrote:
Fri Mar 01, 2019 10:53 am
They have had it on their previous cars too. I wonder what the benefit is
Re: Williams FW42
nacho
nacho
Re: Williams FW42
Twitter reports say car looks nervous, no wonder though with the lack of testing and parts missing.
