Mercedes-AMG F1 W10 EQ Power+
dans79
267
Re: Mercedes-AMG F1 W10 EQ Power+
That would explain why it came off during the race. Hamilton had an off track excursion over the weekend didn't he?
202 105 104 9 9 7
NathanOlder
dans79 wrote:
18 Mar 2019, 18:23
I cant remember him doing so, can only remember Bottas having a couple of moments.
I'm probably wrong though
GoLandoGo
Lewis v2.0
King George has arrived.
GrizzleBoy
GrizzleBoy
35
Ham ran over the kerb at T1 on his first run of Q3 that lost him 5 tenths in sector 1.
Possible that the shock damaged the thin metal mounting arm.of that part of the floor and they needed to repair it.
zibby43
zibby43
M840TR
M840TR
315
via Albert Fabrega
OO7
OO7
171
EDIT:
The red arrow item wasn't new for Australia, it was run in the second preseason test but wasn't initially fitted to the car.
foxmulder_ms
foxmulder_ms
M840TR wrote:
19 Mar 2019, 16:10
https://pbs.twimg.com/media/D2Bs0qSX0AIrxb-.jpg:large
via Albert Fabrega
This is a great picture. Reminds me Su-27.
M840TR
M840TR
315
foxmulder_ms wrote:
19 Mar 2019, 16:59
M840TR wrote:
19 Mar 2019, 16:10
via Albert Fabrega
Well it can certainly make flanking maneuvers.
Nicolas Carpentiers wrote:Interesting details under the Mercedes AMG F1 W10 front wing: strakes not really parallel, and 'mini-cape' at the connection between neutral section and flap
elMaestro
elMaestro
https://www.facebook.com/79511407410/po ... 224447411/ the amount of damage Lewis's car had.
Morteza wrote:
20 Mar 2019, 03:58
https://pbs.twimg.com/media/D2Bf27KW0AAymEl.jpg:large
Not sure what they mean by "mini-cape" at the connection.
zibby43
zibby43
Just_a_fan wrote:
20 Mar 2019, 20:05
Morteza wrote:
20 Mar 2019, 03:58
Had the exact same question, myself.
bill shoe
bill shoe
151
zibby43 wrote:
20 Mar 2019, 22:34
Just_a_fan wrote:
20 Mar 2019, 20:05
The neutral section extends slightly further outboard than it needs to, so it partially extends under the non-neutral section. As highlighted by white arrow.
zibby43
zibby43
bill shoe wrote:
20 Mar 2019, 22:47
zibby43 wrote:
20 Mar 2019, 22:34
Just_a_fan wrote:
20 Mar 2019, 20:05
Very concise and accurate description. Can see exactly what you're referring to now. Thank you.
bill shoe wrote:
20 Mar 2019, 22:47
zibby43 wrote:
20 Mar 2019, 22:34
Just_a_fan wrote:
20 Mar 2019, 20:05
I don't think it does, to be honest. From these two views, it looks like the end of the neutral section is fairly vertical, not projecting out like the cape. It makes no sense to extend the bottom face of the neutral section - you want the air to flow around the edge because that's what creates the Y250 vortex. Extending a cape out from the lower edge doesn't seem to do much.
We need a better, closer, view of the area.
