Mercedes-AMG F1 W10 EQ Power+
bill shoe
bill shoe
151
Re: Mercedes-AMG F1 W10 EQ Power+
Just_a_fan wrote:
21 Mar 2019, 00:18
bill shoe wrote:
20 Mar 2019, 22:47
zibby43 wrote:
20 Mar 2019, 22:34
Had the exact same question, myself.
The neutral section extends slightly further outboard than it needs to, so it partially extends under the non-neutral section. As highlighted by white arrow.
I don't think it does, to be honest. From these two views, it looks like the end of the neutral section is fairly vertical, not projecting out like the cape.
We need a better, closer, view of the area.
I think the most recent pics are clear enough. The "cape" that seemed visible in earlier pictures is just a step-change in height as seen from an awkward angle. So there is no cape. Oops.
GPR-A
37
Floor damage to Lewis' car. Close up picture.
Click to enlarge.
It looks small but they've missed the big bit that sticks out and fills the triangular space between the tyre and the floor. This is quite a big bit (the whole section to the left of the big slot below) and would have messed up the air flowing around the tyre and crucially mess with the diffuser flow on that side.
erudite450
erudite450
Guys, do we know the exact wheelbase and rake angle of 2019 cars yet?
BwajSF
BwajSF
erudite450 wrote:
21 Mar 2019, 11:08
Wheelbase can be determined as it will stay constant all over 2019 for a given car.
But rake angle would vary from circuit to circuit and also weather in circuit will also determine the rake angle and ride height. So, it is close to impossible to have a number for rake angle.
Suvesh
Suvesh
erudite450 wrote:
21 Mar 2019, 11:08
Here it is:
https://www.auto-motor-und-sport.de/for ... utos-2019/
Suvesh wrote:
24 Mar 2019, 14:20
erudite450 wrote:
21 Mar 2019, 11:08
Here it is:
AMuS:
Unsere Messung stammt jedoch aus der ersten Testwoche von Barcelona. In der zweiten hat Mercedes den Anstellwinkel offenbar signifikant erhöht. Nach unseren Informationen um fast 20 Millimeter. Prompt wurde das Auto auch schneller.
However, our measurement comes from the first week of testing in Barcelona. In the second Mercedes has apparently increased the angle significantly. According to our information, by almost 20 millimeters. Prompt, the car was faster.
GPR-A
37
Can anyone explain the benefit the advantages of mountings having been moved upwards? Allison mentioned in his 2018 vs 2019 comparison video that, they didn't know they could go that higher and they have achieved it now. There must be some real benefit of having done that.
Suvesh
Suvesh
GPR -A wrote:
26 Mar 2019, 14:42
I think it allows more clean airflow (unaffected by interference from the wishbones) to pass through to the sidepods and towards the rear of the car, allowing better cooling and cleaner air to generate downforce.
It can also give you better motion ratios with smaller pushrods as the forces are lower from the increased angle.
But that would be a secondary benefit, it's mainly aero driven.
CLKGTR
CLKGTR
101
Just wanted to add that Mercedes F1 W10 is 5733 mm long, not sure it was mentioned before. I calculated the lengths of the 2019 F1 cars by adding front (1225 mm) and rear (810 mm) overhangs to the wheelbase data from AMuS and full data can be found here.
Via @AlbertFabrega
zibby43
zibby43
zibby43
zibby43
Are there 3 hanging vanes now, as opposed to 2, on the Bahrain-spec Merc RW end plates?
