Will Electric Vehicles Be Viable? When?
Big Tea
148
Re: Will Electric Vehicles Be Viable? When?
roon wrote:
Fri Apr 19, 2019 2:46 am
strad wrote:
Mon Apr 15, 2019 4:40 pm
Still not totally sold but if all I needed was a back and forth to work car and building a charging station wasn't so expensive I'd consider one.
Surely charging stations are cheaper to build than gas stations. You don't have to dig big holes in the ground. Regulatory environment is different as there are no local stores of flammable material nor fumes to deal with. Small gas pumps aren't popping up in parking lots in the way charging stations are, for obvious reasons.
Not going to comment on it. But... some people complain that the fans make a noise all night too
http://islingtontribune.com/article/ele ... nt-clutter
We are standing on the shoulders of Giants. So watch your feet.
strad
271
Ya gotta have your own charging station at home. Bring in an electrician pay him to run a 220 feed with dedicated receptacle not to mention paying for the necessary permit to do so.
Probably close to a couple of thousand all included here.
Sir Stirling Moss
Big Tea
148
strad wrote:
Fri Apr 19, 2019 6:50 pm
What if you live in a block or do not have a drive?
subcritical71
94
Big Tea wrote:
Fri Apr 19, 2019 4:53 pm
To be fair, local residents to wind farms complain about the noise the turbine blades make. Local residents don’t like the yellow plume a gas turbine creates during startup. Local residents don’t want a nuclear plant in their back yard. Coal is all but dead. That leaves solar and bio.... can’t imagine what a bio plant would smell like, I’m thinking pretty close to what a trash burner plant smells like. Pilots also complain about the reflections of the mirrors on solar. If we need to keep everyone happy we are screwed. :wtf: :D
Big Tea
148
subcritical71 wrote:
Fri Apr 19, 2019 8:09 pm
I know some one will complain about anything, but a little thought should be involved. Then again, it is not usually the case so...
Andres125sx
355
If that´s the biggest problem, then it´s almost perfect :D
strad
271
Big Tea wrote:
Fri Apr 19, 2019 7:53 pm
Not sure what you mean but not many places here have a group plug in. Each home has to have it's own hook up to charge the vehicle. And that ain't cheap. :wink:
Sir Stirling Moss
Zynerji
Zynerji
89
strad wrote:
Sat Apr 20, 2019 6:13 pm
I fixed a multi-trade company that installed these as part of their services, and it was $495 to install a new breaker, run the wire, and install the receptacle. It was only $645 to run 2 since the labor was synergized.
Big Tea
148
Many live in blocks or arrangements where they do not have a designated parking spot or are not able to bring the car to a position where it can be plugged in.
You cannot just trail a cable across the footpath or pavement/sidewalk nor drop a flex from the 7th floor.
As 60odd % of the world live in cities, and this will be far higher for car owners, there will be many who just cannot get the car into a position to charge, and this means finding an alternative, which would probably involve a queue and lots of waiting in line.
I am pro electric car, but really do not see how we are going to get around the problem without a paradigm shift in thinking about how long it takes and what we do about it.
People living in high density locations would often be better served by better public transport, not individual cars charging at their house.
There is a need for social engineering as much, if not more than, technical engineering.
strad
271
I don't think you are in the U.S.
Not unusual for an electrician to charge $100 just to show up and $100 an hour plus parts. :wink:
Sir Stirling Moss
michl420
michl420
I don`t read everything here but i have a e-car, so. The main "Problem" is that everyone compare electro and gasoline. With a e-car, you drive 2 Hours and charge 1/2 hour. That`s how it is on a Long trip, and only on a Long trip. Even with a gasoline car you would enjoy a pause. I don`t know why it is a Problem that the pause is a Little longer. In everyday operation charging is anyway no problem. Of Course a Garage or at least a charge-station at home is a must have.
roon
roon
449
BMW BEV 700+ hp three motor mule. One front motor, two rear.
izzy
69
michl420 wrote:
Sat May 04, 2019 6:23 pm
yes most journeys are quite short anyway aren't they, but people worry that they'll need a charge and won't be able to find one. We (my parents) tried an i3 and the charging stations that we found one didn't work and the other had an ice car parked in it. But the electric drive was fantastic and even more was a Tesla we tried, it instantly made piston engines seem ridiculously last millenium
The i3 was a great concept with the small petrol engine to charge when you needed it, but just a moped engine bolted in and only a 9 litre tank. What they need is a microturbine for the real long distance cars, for a few years
roon
roon
449
And who makes the best microturbine range-extender for road vehicles to date? F1 teams and their suppliers. Port that thing over. Replace that convoluted ICE with a soda can and some spark plugs. Make a portable genset while yr at it. 40kw in something the size of a traditional 1kw.
