Red Bull RB15
GhostF1
110
Re: Red Bull RB15
Sieper wrote:
28 Apr 2019, 21:19
Max just lost that place to perez as he had to start from P4. The inside here is rather disadvantegous. Last year Max started from P5 himself and he overtook Ric (that started from P4 as well) in the exact same way as Perez on Max this year. Not so much a tire heat up issue.
After the VSC The realease came at an unfavourable moment for Max, plus he was told to stay of the kerbs, compromising the only way to get heat into the tires (the corners in the twist section).
Agreed, I just think he had a less than stellar start from the inside which is not the best anyway, he made ground only a few laps in, to me that's not a fuel efficiency issue, especially while setting plenty of fastest laps, keeping tabs on Vettel and Hamilton and only slowing due to avoiding kerbs for chassis reliability. Not the usual behaviour of fuel saving..
Singabule
Re: Red Bull RB15
Does it brings aero benefit as well, especially to attack tyre wake
Bill
Re: Red Bull RB15
Honda brought spec2 which role was to improve reliability and allow the car to run higher engine mode for longer duration the progress is there and clear to anyone if you compare to China were Max was losing to vettel.now Rbr needs to bring aero improvement if that helps with tyre usage hopefully the can dispatch Ferrari and focus on Mercedes.
loner
16
Re: Red Bull RB15
i would bet on a revised PU area they hinted about shrinking this area leading to free gains plus whatever aero and body they will upgrade as well.
para bellum.
gandharva
252
Re: Red Bull RB15
https://www.skysports.com/f1/news/32420 ... h-upgrades
One of the less publicised but very significant changes to the 2019 regulations was the limiting of the under-wing nose strakes to two each side where previously there was no limitation. These strakes are used to divide up the airflow between that travelling to the barge boards and down the sides of the car and that channelled to the underfloor. They are crucial in joining up the upper and underbody airflow that is such an essential part of how the current cars maximise their aerodynamic performance.
Because of the extreme way its high-rake car works, it seems that Red Bull has suffered more than other teams in this regulation limitation. The car is aerodynamically powerful as it dives under braking into slow corners and its drivers can carry a lot of speed up to the apex, but as its platform then levels out or pitches under acceleration - and stays relatively level in fast corners - that aero performance is somehow being lost to the detriment of rear end downforce, and the area of suspicion within the team has fallen to how those under-nose strakes are directing the flow.
Modifications to how the flow worked this area were what was behind the improvement between Bahrain and China. A more fundamental change, incorporating this new knowledge, is planned for Barcelona.
Flying JPS Lotus
37
Re: Red Bull RB15
Not entirely sure but I'd say that's a new engine cover that looks a lot tighter around the rear.
"Looks like meat's back on the menu boys!"
#AeroUruk-Hai
gandharva
252
Re: Red Bull RB15
Looks like the old cover. Same cutouts and paint job.
Flying JPS Lotus
37
Re: Red Bull RB15
gandharva wrote:
08 May 2019, 23:21
They look different to me, but maybe it's just the different angles.
#AeroUruk-Hai
roon
412
Re: Red Bull RB15
What year did they stop using a one-piece engine cover?
Sieper
73
Re: Red Bull RB15
They look very similar. The only thing I don’t see is the lower part of the Numbers 33 and 10. Those were present behind the Legs of the bull on the lower engine covers. That might at least indicate a changed cover part but they look very similar, the same I would say
See, 33 on the lower engine cover partly. Perhaps just a respray.
Here a more clear picture, lower halve of 33 on the lower engine cover
Flying JPS Lotus
37
Re: Red Bull RB15
roon wrote:
09 May 2019, 00:08
The RB12 from 2016 was the last one.
#AeroUruk-Hai
seense
Re: Red Bull RB15
Flying JPS Lotus wrote:
08 May 2019, 23:10
https://imgr3.auto-motor-und-sport.de/R ... 555098.jpg
Looks to me the left one is different from the right one: the red stripe on the left covers has a sharper bend near the sidepod intake. Updated sidepods?
gandharva
252
Re: Red Bull RB15
Looks like the old frontwing they already used in the first in season test, plus the 3 trays in the central section.
MartijnA3
Re: Red Bull RB15
dxpetrov wrote:
09 May 2019, 16:35
Wtf is this BS?! Hope this is just the old wing, for comparison... If not, they have really become a joke team. The reference they've got about big "Update Package" is not more than a mere practice session item adjustment for Mercedes and Ferrari. No wonder they can't compete at highest level anymore...
Ehm...
https://www.formula1.com/en/latest/arti ... 0l8BH.html
Red Bull have opted for what Horner describes as a “fairly subtle” upgrade for Spain. He added: “It’s basically an evolution so it’ll be the usual front and rear wings upgrades. It’s evolution rather than revolution. [The] development is focused on different aspects of balance, degradation, all of those things.”
Re: Red Bull RB15
Perhaps they've brought old and new parts so that they can compare them on track. That would be an entirely sensible thing to do.
