Mercedes-AMG F1 W10 EQ Power+
AMG.Tzan
37
Re: Mercedes-AMG F1 W10 EQ Power+
SuperCNJ wrote:
03 Jun 2019, 15:12
zibby43 wrote:
01 Jun 2019, 19:05
Mercedes will debut their Spec 2 PU in Montreal.
Output is rumored to be at 1,020 horsepower. A significant increase in power for Mercedes.
"Mercedes will debut engine 2 that will be capable of more than 1,020 horsepower, with a significant increase in power, but without affecting the reliability"
- Motorsport (Italy), last paragraph
https://it.motorsport.com/f1/news/ferra ... h/4415276/
I always wonder where the journalists get this information and how reliable it is.
Also, any idea how much power Mercedes had before this upgrade and how the Ferrari PU compares?
Somewhere in the Engine Threads there is a post from preseason testing where a journalist using some kind of device that somehow measures horsepower said Ferrari and Mercedes were both at 990 hp. Don't know if it's true though...
-I hope 1020hp is true...at last we can say: Formula 1 engines produce over 1000 hp!! :D =D>
marvin78
marvin78
AMG.Tzan wrote:
03 Jun 2019, 15:32
SuperCNJ wrote:
03 Jun 2019, 15:12
zibby43 wrote:
01 Jun 2019, 19:05
And why is that important?
KiLLu12258
KiLLu12258
marvin78 wrote:
03 Jun 2019, 15:34
AMG.Tzan wrote:
03 Jun 2019, 15:32
SuperCNJ wrote:
03 Jun 2019, 15:12
sounds good :)
AMG.Tzan
37
KiLLu12258 wrote:
03 Jun 2019, 15:36
marvin78 wrote:
03 Jun 2019, 15:34
AMG.Tzan wrote:
03 Jun 2019, 15:32
sounds good :)
Hahaha...that's what i was about to say!! :lol:
zibby43
zibby43
613
SuperCNJ wrote:
03 Jun 2019, 15:12
zibby43 wrote:
01 Jun 2019, 19:05
It was reported that there was a phonometric analysis done in Bahrain this year. It's a type of sound analysis that teams use, in conjunction with GPS traces, to analyze PU performance. This type of analysis was even more important before the implementation of GPS.
The analysis estimated peak outputs of 990 horsepower for both Merc and Ferrari in Q3.
One of the more interesting observations from the analysis was that it seemed the Ferrari was able to make better use of the electric power of the MGU-H, whereas the Merc seemed to have a small advantage with respect to the endothermic engine.
The ultimate conclusion of the analysis was that the 2 engines were on par with one another, and that the W10's straightline speed deficit likely comes down to the car's inherent design (draggier) and the fact that Merc were running more wing than Ferrari in Bahrain.
Big Tea
AMG.Tzan wrote:
03 Jun 2019, 15:32
SuperCNJ wrote:
03 Jun 2019, 15:12
zibby43 wrote:
01 Jun 2019, 19:05
I believe the device used by journalists to measure HP of a F1 engine is the 'wet finger'.
It comes in 2 forms. First it is held in the air and a guess made, or more technical, spill from the glass being carried to someone who claims they know and will tell for a drink.
(yes, I know there are serious journalists out there, but I don't think they are qualified to use this particular equipment)
digitalrurouni
digitalrurouni
1020 hp or thereabouts with such a restrictive set of rules with regards to fuel flow, and 3 engines per season is a remarkable achievement if you ask me. Do you think under the same regulations more output could be extracted if they change the specifications of the MGU-H and K like more powerful batteries or a bigger hp output out of the electrics?
Jolle
Jolle
132
digitalrurouni wrote:
04 Jun 2019, 17:47
The size and flow of energy from and to the H is not limited or regulated, only the max turbine speed. If they would increase the K and/or the flow of energy to the K and ES it will of course make the PU more efficient and more powerful.
dans79
267
Jolle wrote:
04 Jun 2019, 18:11
04 Jun 2019, 17:47
I agree, and i think it would be cheap. Right now I think all the engine manufactures are all chasing minuscule ICE gains because that's all the rules allow them to do right now.
197 104 103 7
I've never been one to trumpet "road relevance" of F1 - I don't think it is/should be aimed at road relevance - but having said that, I'd bet Mercedes are learning a lot of stuff that they can apply/adapt to their road vehicle systems.
erudite450
erudite450
dans79 wrote:
04 Jun 2019, 18:18
Jolle wrote:
04 Jun 2019, 18:11
04 Jun 2019, 17:47
I'm surprised the manufacturers aren't pushing for more flexibility with the MGU-K and Energy Storage. One would have thought it would aid their R&D for their road cars.
digitalrurouni
digitalrurouni
Jolle wrote:
04 Jun 2019, 18:11
04 Jun 2019, 17:47
Thanks for replying. So when you said the max turning speed is regulated you are taking about the MGU-H turbine speed. And the flow of the energy to the K and ES that you are referring to is that the 4 MJ limit?
Wonder why then the regulations are restricting the PU with such numbers if they want to push the green agenda wouldn't they allow more 'recovery' basically than say ICE development?
Sierra117
04 Jun 2019, 19:14
Jolle wrote:
04 Jun 2019, 18:11
04 Jun 2019, 17:47
I think it's because it's the ingenuity and working around and within the regulations that results in genius solutions that are thr most efficient solutions that then can be applied to the mainstream. Relaxing the constraints and allowing for more input of resources is actually reducing efficiency. Something similar is altitude training where your lungs and overall circulation system adapts to deal with the thinner air and lower oxygen level (for athletes). Just my view.
NIKI LAUDANZ SolidarityCubolligraphy | Instagram | Facebook
#Aerogorn & #Flowramir
Jolle
Jolle
132
04 Jun 2019, 19:14
Jolle wrote:
04 Jun 2019, 18:11
04 Jun 2019, 17:47
Both the ICE as the recovery is more develop working models where for road use the ICE could be scaled down and the ERS scaled up for instance. The actual size doesn’t matter for that. But, if for instance they would half the ICE and quadruple the ERS, you would have strange off throttle recovery and other efficiency tactics that wouldn’t be “racy”, just like the CVT that Williams build in the nineties.
At the moment the current F1 is a perfect proof of concept. A very efficient and reliable turbo engine with no turbo lag.
The 1984 TAG Porsche, unlimited only with the amount of fuel per race 220 liters (around 180 kg I guess?), no boost limits or durability goal of 310 km, has 650 hp during the race.
The turbine speed must not exceed 125.000 rpm by the way and I don’t think the H unit is allowed to be geared.
Longley
Longley
Do we see here a more tight-fitted engine cover / sidepods?
It looks like you can see the curvatures of the coolers and the exhaust under the shell.
