Mercedes-AMG F1 W10 EQ Power+
ENGINE TUNER
ENGINE TUNER
26
Re: Mercedes-AMG F1 W10 EQ Power+
https://www.youtube.com/watch?v=EgLzNttPco0
So, the variable engine cooling ducts just below the rear mounts of the halo, the covers that they place on there for qually, they are removed during the pit stops, but is it within the regulations to rig up a system where the driver himself can remove them during the first stint.
Hamilton specifically suffered with the same engine overheating in traffic issues in Canada 2018, and both cars in Canada 2019.
izzy
izzy
So this is the inside of the wheel, that they were developing towards the end of last year:
The first thing is that the notorious SPACER isn't anything to do with the aero it has lots of little holes that get air from the hub face and vent straight away into the general space inside the wheel. It really is just an insulator
The second thing is that there's a small hole going through from the space around the axle, that goes into the new extra hole in each spoke. And we can see that this space is sealed at the far end with that flange that has lots of little holes in it. This must get high pressure air from the brake duct, and its job is to be a jet that entrains air to flow through the spokes
Then there's the Texture on the inside of the rim, which as i pointed out in the tyre temperature thread only has a smooth surface on the other side not a textured or even roughened one. So its job can't be heat transfer, it can only be to stir the air around the outside of the cake tin into rotating.
So this is a recipe for a VORTEX, and even for an outwashing vortex =D> . I'll do a post from the outside of the wheel in a bit
zibby43
zibby43
611
The Stroll Spec 2 PU ICE failure was due to a faulty spark plug.
Mercedes has rectified the issue for France.
https://www.motorsport.com/f1/news/merc ... l/4476897/
dans79
252
izzy wrote:
Tue Jun 18, 2019 4:36 pm
The dimples increase surface area, and aid in heat transfer. They have been around since 2013, as can be seen here.
https://www.f1technical.net/development ... -the-tyres
191 103 103 7
izzy
izzy
dans79 wrote:
Tue Jun 18, 2019 6:00 pm
they would do, if there were dimples on the other side. But the other side is smooth, so as it is, the heat can't get out as fast as it can get in, so the dimples can't be about heat transfer. If they wanted to TRANSFER heat, across the membrane, they'd have both sides textured
Texturing only one side means it's not about heat. And same thing with the fins. It'd be so easy to texture the inside, and they haven't
Here they are again, smooth as a baby's bottom :)
dans79
252
izzy wrote:
Tue Jun 18, 2019 6:57 pm
My assumptions has always been that they wanted it this way on purpose.
Transfer a bunch of heat into the rims in braking zones and earlier on in the acceleration zones, when the brakes are at their hottest. Then slowly let it leach out into the tires on the straits to counteract the cooling of the tires.
191 103 103 7
mantikos
mantikos
34
https://d2d0b2rxqzh1q5.cloudfront.net/s ... 918406.jpg
That is decidedly inaccurate and a terrible assumption. Does your heatsink have fins on both sides or only on one?
hollus
Then a heatsink draws heat from a flat surface, and this would take heat from hot air.
dans79
252
mantikos wrote:
Tue Jun 18, 2019 7:20 pm
This isn't a great analogy either, as it depends on what the heat is being transferred from/to.
[*] solid to air
[*] solid to liquid
[*] air to air
[*] air to liquid
[*] etc
in the case of tires you are talking air to air.
191 103 103 7
izzy
izzy
a heatsink generally isn't air to air, as Hollus says. When the medium is the same, the surface has to be the same, if all you want to do is transfer from one side to the other
LM10
LM10
102
Didn’t Mercedes start with those rims to solve their overheating issues? If so, shouldn’t this explain the purpose of them?
izzy
izzy
LM10 wrote:
Tue Jun 18, 2019 7:39 pm
but when you look at the detail of it, that doesn't really fit does it. The texture around the cake tin would warm the wheel up, while the fins would cool it down. If they wanted the fins for cooling, they'd have textured the inside of them
Of course Mercedes must have been loving it while everyone was talking about the cooling, even tho probably the other teams knew and i read Ferrari were working on it. And the context was, being desperate for outwash
mantikos
mantikos
34
dans79 wrote:
Tue Jun 18, 2019 7:26 pm
[*] solid to air
[*] solid to liquid
[*] air to air
[*] air to liquid
[*] etc
I agree its not the best analogy BUT, I also don't think that the small protrusions on the rim rise above the boundary layer to generate a meaningful vortex. The answer to everything can not be a vortex.
dans79
252
mantikos wrote:
Tue Jun 18, 2019 7:58 pm
I didn't suggest anything about vortexes, I'm suggesting that are there purely to aid in heat transfer into the rim.
191 103 103 7
izzy
izzy
it's F1, if it's not heat and it's not a vortex what do you think it is? do you have a third subject you can switch to? :P
The rears were prone to OVERheating, why would they try to add heat with a texture? And why do you think those extra holes appeared in the spokes, front and rear? that have a mysterious little hole leading into them from the axle. are you going to acknowledge they exist?
cos vortices have some great qualities, and one of them is they attract each other. so if you flow a big fat vortex past a wake what's gonna happen? If you flow a small, fast jet of air through an orifice what happens? when the orifice is rotating :idea:
