Mercedes-AMG F1 W10 EQ Power+
zibby43
zibby43
Re: Mercedes-AMG F1 W10 EQ Power+
Nice shot that. =D>
zibby43
zibby43
Just_a_fan wrote:
02 Sep 2019, 11:16
Nice shot that. =D>
Didn’t realize they were running the sawtooth-edged mainplane until I saw that shot.
mkay
mkay
16
Will Mercedes bring an ultra-low downforce wing for Monza, or just re-use the Spa package?
zibby43
zibby43
mkay wrote:
02 Sep 2019, 20:56
The specification they raced at Spa is the lowest-downforce spec that we've seen them use the entire season.
In Baku, Mercedes tested (cannot remember if they raced it) a front wing that had the uppermost chords trimmed out (similar to what Ferrari utilized at Spa) and the inboard tips re-profiled slightly. I don't know if Merc utilized that FW in Spa. We didn't get a ton of technical photos of the W10 during the past weekend.
mkay
mkay
16
zibby43 wrote:
02 Sep 2019, 23:29
mkay wrote:
02 Sep 2019, 20:56
I was well aware that it was the lowest-downforce spec, just wondering if people think Mercedes will do further thinkering to shed some drag (T-wing, front/rear wing, etc.) given Monza doesn't really have the mix of corners Spa does.
SiLo
139
They might do? Taking downforce off is easy but doing it without upsetting the balance of the car can be hard.
Felipe Baby!
auv
auv
Whatever wing they would bring for Monza, it would not be less draggy than Ferrari's one.
digitalrurouni
digitalrurouni
So can someone explain to me how if a car is very draggy a la Mercedes and is producing a ton of downforce can't be tweaked to produce a very slippery car with less downforce? Almost seems like Mercedes doesn't know how to make slippery cars because they've spent so much time making a draggy downforcey car.
Across the season as a whole, more downforce is more important than less drag.
dans79
267
digitalrurouni wrote:
03 Sep 2019, 13:42
It's not that simple, when you go with a given design philosophy you can't make drastic changes to it without messing up with the car's aerodynamic balance.
202 105 104 9 9 7
zibby43
zibby43
mkay wrote:
03 Sep 2019, 12:26
zibby43 wrote:
02 Sep 2019, 23:29
mkay wrote:
02 Sep 2019, 20:56
My point in emphasizing the entire season was establishing that, with Mercedes, we usually see them test lower-downforce options before racing them. And your initial question only referenced the rear wing, which I addressed (and more).
If you haven't seen a lower-downforce spec yet this season, you're likely not going to see it at Monza.
I already addressed the front wing part of your question.
atanatizante
125
In the post-race press conference, Lewis said, I quote: ..."I think we’ve got some improvements to try to make to the car within four days ..." so they have something special for this race, presumably aero I think ...
Then, Toto said the 2 PU failures forced to run them in the race in a conservative mode, without the highest race PU mappings ... that`s the second statement on this matter and could be one reason behind that 15km/h deficit to Ferrari on the straights at Spa ...
To me that Merc has other philosophy than Ferrari when they introduce a new spec: they - both customers and works team - just run them in a lower PU mode (or better say not in the highest PU modes) in order to have some real track data but most of all to calibrate them fully at the next race, which by the way is Monza ... Ferrari is even more conservative on this matter and just lets the customer's teams be their "guinea pig tests" and do this pre-phase of new spec PU introduction ...
It seems that Merc has just arrived at a dead-end regarding their PU "architecture" philosophy and must focus in the future to those areas which Ferrari has outperformed them: combustion and MGU-H ...
On another note, how much time the PU manufacturers do they take in R&D + dyno tests prior they run a new PU spec? I`ve read somewhere they need at least 6 months in advance ... so for this 3rd spec. 2019 PU they were starting way back at the beginning of the springtime ... and they are now working for the first 2020 PU spec. it seems ...
Jesus
Bill
Bill
These pu units have a thermal efficiency of 50% they is another 50 to go hardly a dead end.maybe Mercedes are finding it hard to find extra power without dodgy oil burning what's funny was Ferrari was supposed to be the cheating one with smoke bellowing out of the exhaust when ever they leave the pit and extra sensors they were carrying.
