Red Bull RB16
Re: Red Bull RB16
Bandit1216 wrote:
18 Feb 2020, 21:40
scarbs wrote:
18 Feb 2020, 18:18
Bandit1216 wrote:
18 Feb 2020, 11:50
Nobody?
It's a unique set up, the rack is midway between the top and bottom wishbones, but placed rearwards, nearer the front axle line than the front bulkhead. The track rod then reaches backwards to pivot on the upright behind the front axle line. It even passes behind the pushrod.
Easier to create an Ackerman setup, to turn the inner wheel and lower its ride height via the POU geometry
Hmmm. Don’t quite grasp it. I have seen Williams is the only team still putting a steering rod in mid airflow, which seems less efficient to me. I thougt all other teams place the rod in front of the lower or higer wishbone, and integrade the teardrop shape as both rods being one teardrop shape. But with the RB16 I can’t see any separate steering piece. I hope my English is suffient to get what I mean.
Might help to understand pro vs anti Ackerman steering.
Re: Red Bull RB16
scarbs wrote:
18 Feb 2020, 23:02
Explained more deeply and with images on twitter here.
Could be to maximise the blowing in the wheels. Brake ducts can be even better flowing now that they don't have to dodge the tie rod.
Re: Red Bull RB16
What about the obvious negative caster up front?
Bandit1216
21
Re: Red Bull RB16
Hi all.
Thanks. I know the ackerman principle. I still cannot see the track rod itself though.
But just suppose it weren't hypothetical.
Re: Red Bull RB16
NtsParadize
NtsParadize
Re: Red Bull RB16
New front wing air intake?
Re: Red Bull RB16
Via AMuS
Re: Red Bull RB16
Secondary bulkhead? Odd..
Jolle
Jolle
132
Re: Red Bull RB16
19 Feb 2020, 11:59
Or, with the steering rack further back, this is the primary and the got the brake stuff all inboard. I hope their main brake bleeder mechanic has small hands 😂
dxpetrov
dxpetrov
-7
Re: Red Bull RB16
The car looks like on rails...
Re: Red Bull RB16
It should. It has a lot more downforce than last year. So much so that I'm worried about speed traps.
Juzh
161
Re: Red Bull RB16
TBH when we were onboard with max like 10 minutes ago the car seemed a bit loose on the rear. It turned well enough but rear wasn't having it. Verstappen was doing corrections all the time. He was on some sort of long run on hard tires though, which might not be firing up in the cold. Not sure what to think.
Sieper
73
Re: Red Bull RB16
that is also what I saw in the silverstone film day run (only images I have seen sofar) the rear end was not totally stable. Otoh he is on 71 laps right now, most of anybody.
Re: Red Bull RB16
That looks like a medium downforce rear wing.
dren
226
Re: Red Bull RB16
And how much might that be?
Honda!
