Alfa Romeo C39
astracrazy
astracrazy
31
Re: Alfa Romeo C39
Those sidepods look small, the livery is hiding it.
KingLoe
KingLoe
Re: Alfa Romeo C39
I tink they can, of you look closely you see the alfa Romeo lettering underneath the snakeskin
JRodrigues
JRodrigues
Re: Alfa Romeo C39
cramr
cramr
Re: Alfa Romeo C39
kalinka wrote:
Fri Feb 14, 2020 2:31 pm
It almost look like that they can just peel off that snake-skin and have the normal livery under :o
It's probably just a vinyl on top of the painted car
aral
aral
26
Re: Alfa Romeo C39
How clever to incorporate the Alfa shield shape into the nose inlet !
sebastian.vidu
sebastian.vidu
Re: Alfa Romeo C39
aral wrote:How clever to incorporate the Alfa shield shape into the nose inlet !
It's called Scudetto
Sent from my SNE-LX1 using Tapatalk
ScrewCaptain27
570
Re: Alfa Romeo C39
It also has POU.
- Serj Tankian
f1316
f1316
65
Re: Alfa Romeo C39
The sidepods remind me of the red bull.
Ringleheim
Ringleheim
Re: Alfa Romeo C39
This "snake skin" livery isn't the new look, is it?
I assume this is an introduction thing and we'll see the real livery in testing?
nokivasara
nokivasara
Re: Alfa Romeo C39
ScrewCaptain27 wrote:
Fri Feb 14, 2020 5:34 pm
It also has POU.
What's that?
lio007
271
Re: Alfa Romeo C39
nokivasara wrote:
Fri Feb 14, 2020 8:55 pm
It also has POU.
What's that?
Pushrod on upright
The car is running with a Pushrod On Upright set up, often termed (POU or PROU). Many teams run with this set up, the offset from the pushrod pickup and the king pin axis is a tuneable set up parameter. I have seen F1 set up sheets with figures of 8mm offset.
I had it explained to me by an ex-f1 designer: "When the car turns the outside wheel will drop and inside will rise, this helps grip at low-speed. Its often used in conjunction with Anti-Ackermann suspension (meaning that the outside wheel steers faster than the inside), this can then result in an overall reduction in front-ride-height as you add steering lock."
nokivasara
nokivasara
Re: Alfa Romeo C39
lio007 wrote:
Fri Feb 14, 2020 9:10 pm
It also has POU.
What's that?
Pushrod on upright
Oh I see! Thanks, I noticed that abbreviation on several of the threads on this years cars and could not make anything out of it, other than it was something about the suspension/uprights.
monkeyboy1976
monkeyboy1976
Re: Alfa Romeo C39
zibby43
zibby43
560
Re: Alfa Romeo C39
via Thomas Maher and Adam Cooper
zibby43
zibby43
560
Re: Alfa Romeo C39
Nose on the A. Romeo:
