Also depends on how realistic the threat/chance of rain is for Sunday.
And it might have to do if they expect to qualy in front or behind Merc 2.
There's a small chance it rains towards the end of the race.
From this angle seems more low DF than the other pics posted here. Also Merc is running a similar setup
main plane looks to be the same as Spa spec, in depth and profile, with a low AOA on the flap and the top edge trimmed off
My money is on the fact they are bringing a new front wing and a couple other pieces so they are keeping the rear wing and setup relatively similar to data they gathered at Spa or previous races to check correlation for the new one. Will likely change as FP sessions progress
If Albon's problem is snapping, a front wing mod may balance the grip better for him. Hope it fixes his confidence. Max seems able to drive what ever turns upGhostF1 wrote: ↑Fri Sep 04, 2020 12:11 amMy money is on the fact they are bringing a new front wing and a couple other pieces so they are keeping the rear wing and setup relatively similar to data they gathered at Spa or previous races to check correlation for the new one. Will likely change as FP sessions progress
