McLaren MCL35
haza
haza
Re: McLaren MCL35
haza wrote:
13 Sep 2020, 10:21
charliesmithhd wrote:
11 Sep 2020, 15:10
haza wrote:
11 Sep 2020, 15:01
I actually was surprised with the nose change I drew a 3D model of something very similar for the MCL-35 though my design had a double flapped cape and 2 openings at the top Sides of the Nose and exit tunnels at the bottom to create a Z-duct
Is it possible to post have a screenshot of it? Seems interesting
I’m still working on the concept but I can give you all an idea on the concept, the idea is for the nose to have 3 openings one at the tip an 2 on the top sides of the nose the idea is for airflow to go through these channels and out of 2 tunnels that exit at the bottom rear of the nose theoretically it should send the airflow through the nose and out the bottom towards the turning vanes and bargeboards and the cape is effectively a double cape that is basically designed to add a small amount of downforce it is still very early designs and I am yet to do CFD Simulations between the current nose and my concept for comparison
I’m hoping to incorporate this concept physically on a chassis I’m building
M840TR
M840TR
315
Re: McLaren MCL35
haza wrote:
13 Sep 2020, 10:21
11 Sep 2020, 15:10
haza wrote:
11 Sep 2020, 15:01
The 2018/2019 nose was actually very similar to this. The central nostril exited at the bottom of the cape, creating a low-pressure zone underneath. The problem with the vented nose philosophy seems to be consistency of airflow and robustness of the structure. The current nose already hangs by a thread on the fw neutral section; if you remove the bulky pillars like on the Mcl35 while creating a hole significant enough for airflow to pass through for aero, then the crash structure is compromised. But if you create holes large enough for aero on a slim nose then you'd have to make the mounts bulky which impede the air and make it inconsistent.
haza
haza
Re: McLaren MCL35
M840TR wrote:
13 Sep 2020, 10:47
haza wrote:
13 Sep 2020, 10:21
11 Sep 2020, 15:10
I did think about this (fw mounts) and I opted to actually build the wing into the nose instead of hanging on mounts
haza
haza
Re: McLaren MCL35
haza wrote:
13 Sep 2020, 11:01
M840TR wrote:
13 Sep 2020, 10:47
haza wrote:
13 Sep 2020, 10:21
Also the main 2 opening are towards the rear of the nose rather than the tip
Carlen
Carlen
Re: McLaren MCL35
Hello everyone! In the next year we will have fuel and lubricants from Petronas or Gulf?
the EDGE
the EDGE
68
Re: McLaren MCL35
Carlen wrote:
20 Sep 2020, 21:50
Hi Carlen. This thread is to discuss the MCL35
The thread to discuss anything else about Mclaren is the team thread viewtopic.php?f=15&t=28681&start=4305
The answer is however Petronas, Gulf will however supply lubricants to every new McLaren road car
Carlen
Carlen
Re: McLaren MCL35
the EDGE wrote:
20 Sep 2020, 22:01
Carlen wrote:
20 Sep 2020, 21:50
Ok. Thanks for the answer
_cerber1
302
Re: McLaren MCL35
SmallSoldier
SmallSoldier
488
Re: McLaren MCL35
That’s a good article... Thanks for posting!
siskue2005
siskue2005
70
Re: McLaren MCL35
So basically similar concept as Mercedes
Re: McLaren MCL35
Interesting Flow....
_cerber1
302
Re: McLaren MCL35
Most likely, this is the profile of the nose itself, and the paint just spread over it.
Re: McLaren MCL35
_cerber1 wrote:
24 Sep 2020, 14:20
He's talking about the airflow in the flow-vis. You can actually see the airflow in the paint (flow-vis).
Macklaren
Macklaren
Re: McLaren MCL35
no pitlane pics yet??
bauc
35
Re: McLaren MCL35
