McLaren MCL35
CjC
CjC
Re: McLaren MCL35
f1rules wrote:
14 Nov 2020, 14:43
Just noticed they have the floor extensions/appendage in front of the rear wheels
https://pbs.twimg.com/media/EmyOKL-XcAAdGWp.jpg
Wow that first made an appearance in Austria 2?
Just a fan's point of view*
Re: McLaren MCL35
CjC wrote:
14 Nov 2020, 15:53
f1rules wrote:
14 Nov 2020, 14:43
It's significantly larger than it was Here on Oct 30th.
Re: McLaren MCL35
Stu wrote:
14 Nov 2020, 13:26
Great pics!
Do you think that they are using the metal part across the entry to the central tunnel to form ‘jets’ of air, or are they form small vortices to prevent stall?
Vortexes to reduce drag. I think it's almost impossible to stall there....you stall much closer to the front from there, if you were to stall.
CjC
CjC
Re: McLaren MCL35
diffuser wrote:
14 Nov 2020, 17:44
CjC wrote:
14 Nov 2020, 15:53
f1rules wrote:
14 Nov 2020, 14:43
https://pbs.twimg.com/media/ElllQ63XYAE ... ame=medium
No I referring to this from the 10th of July- Austria 2.
https://www.f1technical.net/forum/viewt ... &start=675
It’s taken them over 3 months to get in on the car for the race from it being initially tested.
It seems to be taking Mclaren a looong time to get parts to work on the car this season....
Re: McLaren MCL35
Did they qualify with the new front wing or their hybrid version?
Re: McLaren MCL35
godlameroso wrote:
14 Nov 2020, 18:40
Looks like the old one...
Chicane
Chicane
Re: McLaren MCL35
In a nutshell, new front wing and bargeboards a thumbs up but the new front wing has failed to generate desired results. As they say you learn more from your failed attempts than succesful ones so all the data from Norris running the front wing from Russia would be like gold dust for McLaren.
The 2021 floor change is not as simple to adapt to as originally anticipated especially with the diffuser also shrinking in size. Even though McLaren are downplaying aero gains because of PU change i expect McLaren to be making significant use of the more compact Merc PU.
McLaren have lost a lot of points because of PU issues, bad luck, poor pitstops and on track incidents . So the team know that the car has been decently competitive that they are still in hunt for third.
I think those couple of tenths Ricciardo will bring to the table will make McLaren's life a lot more easier next season both on Saturdays and Sundays in a cut throat midfield. McLaren are missing that top reference every team needs to truly understand where the car stands. I rate Norris and Sainz and have no doubt Norris will improve further in 2021 especially from Ricciardo's influence but i have no doubt in my mind that had Ricciardo driven for McLaren this season McLaren would have sealed third on the championship by now even accounting for all the reliability issues and bad luck that they have had so far this season.
Quickshifter
michl420
michl420
Re: McLaren MCL35
It can be seen since the first race this year that the characteristic of the car is becoming more and more like the mercedes. This weekend proof it very much.
Herr_Koos
Re: McLaren MCL35
f1rules wrote:
14 Nov 2020, 15:32
And they continue to suck
Not in the race, they didn't.
Re: McLaren MCL35
diffuser wrote:
14 Nov 2020, 17:51
Stu wrote:
14 Nov 2020, 13:26
Great pics!
Vortex generators to prevent stalling of the central part of the diffuser. That central section is so steep that air will separate from it causing it to stall.
f1rules
f1rules
634
Re: McLaren MCL35
yeah that i have to admit, and great save by the drivers
Herr_Koos wrote:
16 Nov 2020, 10:42
f1rules wrote:
14 Nov 2020, 15:32
Re: McLaren MCL35
michl420 wrote:
15 Nov 2020, 14:07
Not sure what this means.
Re: McLaren MCL35
Just_a_fan wrote:
16 Nov 2020, 11:01
diffuser wrote:
14 Nov 2020, 17:51
Stu wrote:
14 Nov 2020, 13:26
Great pics!
Ok, makes sense.
michl420
michl420
Re: McLaren MCL35
diffuser wrote:
16 Nov 2020, 16:37
michl420 wrote:
15 Nov 2020, 14:07
Friday, Saturday and first half of the race Ham and the Mclaren were slow, as it dry up and there was a chance for tyre temperatur the cars beginn to work. Things like this can be seen since the beginning of the season but of course not that extreme.
Re: McLaren MCL35
michl420 wrote:
16 Nov 2020, 16:49
diffuser wrote:
16 Nov 2020, 16:37
michl420 wrote:
15 Nov 2020, 14:07
Think you missed a very important point where McLaren changed to an 2nd set of inters in the race and went faster. Bottas and Stroll did the same,overheated them and went slower. Hamilton/Perez didn't change thier tires and things went well for them.
Too me that shows that the Merc and the RP are getting alot more heat into thier tires than McLaren. The Merc and RP, when they replaced their tires, the new tires overheated. While the Merc's that didn't replace thier tires , the tires don't hold as much heat when worn, kept running well. While the McLaren's changing the tires allowed them to generate more heat in them and get inside the best operating window of the tire.
So I see a really big difference there in getting heat into the tires between the mercs and the McLaren.
I always wondered what Merc do to get so much heat into their tires. Downforce and mechanical grip are part of the equasion. Wonder if that's all it is.
Anyways this is not a topic for this Forum, it's for the other McLaren forum.
